I would never do this. It's too much of a fire risk. At one point I had my stuff in the attic and one of the fans got jammed by an insect. Fortunately I spotted the issue before the thing caught fire.
Have a search for my house build thread.
I put an entire house worth of networking equipment under the stairs, including 1x 16 port telephony panel, 2x 48 port cat 6, coax distribution amp, surround sound and stereo ceiling speaker feeds.
This is about 18 months old, but you get the gist
I wanted to mount the rack to the wall but
I was not sure how to do this as I could only really see two holes on the top of the cabinet.
Most Non-POE 24 port switches are fanless.. I use a HP 1920-24G but you may not need something as fancy. It was about £150.
so just an update as I am now looking for a 24 port switch or something similar..
I got the area under the stairs sanded and cemented and just about managed to get a lick of paint there
It is very messy under the stairs but the following has been completed and or bought:
- 6u Data rack cabinet
- 24 port patch panel
- BT master socket under the stairs
- 3 X Electrical sockts
- Broadband installed BT
- cables tidied up
- CCTV system
Violla:
Also there is a very irritating metal old pipe there so I had to slightly elevate the rack with a few bricks... I intend to saw away the metal pipe and then put nice bits of timber underneath the cabinet when I get a chance.
I am now looking for a networking switch I want something very quiet I hate noise
prob 20-24 ports.
Got any suggestions?
That metal pipe to the right of the pic is an old Gas pipe i would avoid cutting that tbh.
Try having several people trying to use wifi all at once.
