Rig Advice -£600
Look forward to reading it :) Also my DRAM frequency according to CPU-Z is 800 Mhz and Max Bandwidth 800 shouldn't this be 1600Mhz?
Ah i see, i all new to this side of it, i was plug and play up to now :) I will just be happy if i can play BF3 and BF4 with reasonable FPS (I was getting 15-20 tops from my last system with everything on low), if it does that i won't overclock :)
You'll be getting >60fps with BF3 ultra with no AA, you will probably reach 60fps with AA if you overclock the 7870.
A small overclock (e.g. 4GHz) is well worth it on the CPU. It won't cause heat problems and gives a boost, but you can get to that later.
Mixture of Ultra and High mostly Ultra im getting 115+ FPS according to MSI Afterburner, absolutely couldnt be happier, well pleased :) Just out of chance any of you fancy some properly organised BF3, 32 v 32, 8 hours battles, every Saturday, over an 11 week campaign, check out www.21CW.net say BanJaxGav sent ya! :)
