Ring Size Help (stop it!)
Status
Not open for further replies.
Feek said:
It's just happened again :eek: :)
K.
Likewise. :D
Best suggestion I've got is using a thin stip of paper, roll it up loosely and let it unroll inside the ring, pencil mark where it overlaps, measure the distance from the end to the pencil mark and tell them what that measurement is (internal circumference) and ask if they can do it from that info.
AndyBorzi said:
Who would have thought an innocent thread about sizes of rings would have brought so much laughter!
Anyone who's been on here more than, oooh, five minutes? ;)
I think the cardinals kissing the Pope's ring is a bit suss too! :eek:
Try here best you will get short of going to a jeweller. If you can check the ring yuo are replacing the ring size (unless it has been resized) should be on it.
Status
