Deleted member 70857
Hi,
Is there a programme I can use for free to rip my CD's to .flac?
Cheers
Cheers
I keep trying different versions of EAC and for some reason it won't detect cds inserted into my optical drives on my PC. On another machine they're detected fine with a free little utility called "Freecdmp3ripper" which can convert to *.flac and *.wave files.
From memory that sounds like an aspi driver issue.
dBpoweramp CD WriterSlighty OT, so sorry but what would you use to get a FLAC rip back onto CD?
Using the cue file created with EAC if you're using it, then EAC itself![]()
Can you do anything if you don't have the CUE file?
