Risen performance problems.
13 Apr 2009
Im at a loss as to whats going on, ive tried everthing unistalling drivers, software everything to see whats going on, here is my spec:
Vista Ultimate 64
Core 2 Duo E8400
8Gb Kingston Hyper Ram
XFX 4890
WD SATA Black 640GIG HD
OCZ 700W PSU
The problem is im playing the game @ 1920x1080 and everthing set to the max im getting about 32fps 40 tops, Is this game intensive on the gpu at all?
Any advice would be great :)
That's probably the right kind of FPS you should be getting. Have you enabled AA or AF?
Edit - Is vsync enabled? (I hate asking this question)
That appears to be very wrong.
Specs:
Core2duo o/c 3.2ghz
ATI 4890 o/c slightly i forget the exact figure
8gb ram
Vista ultimate 64 with sp1
1920x1200, max settings, 8xAA, 16xAF, everything set to quality in the control panel
Catalyst 9.10 rc 6
50-100 fps depending on the area im in.
Only annoyance is i get extreme whining from my card when i go into the game menu or quest log, weird.
In CCC perhaps. Thing is if you've ruled out drivers and things then I can't really see for myself. What is frequency on your E8400?
Have you tried checking you have sp1 and using the drivers in my post?
I very much doubt he has vsync enabled unless his screen refresh rate is 40hz. I cant seem to force vsync on this game anyway :S
We should keep this thread open. Risen is a very demanding game, that will be a good benchmark for some of the upcoming ATI 6 series and Nvidia's Fermi.
As for the below quote...
Specs:
Core2duo o/c 3.2ghz
8gb ram
Catalyst 9.10 rc 6
The only thing wrong here, is your fibbing.
-I take it you changed the executable name, in order to get the AA to work at the driver level correct? You knew that right?
-Why are you running driver level AF when the game offers it internally?
-You haven't spoken about any .ini adjustments : Object culling, shadow map, SSAO, etc.
50-100fps? That's a fair representation, IF you're staring at a wall, or down in a dungeon.
Even with a 5xxx card, at the settings you propose, you'd be averaging 35-40sh frames during the daytime hours when running about the open world, and 30-40 at night, especially moving through towns and villages. About the only time you get a consistent 45-55sh is in secluded areas.
The thread author claimed to get 35-40 tops, and I suspect that's an average he observed when roaming the outdoor areas. Which, kinda sounds about right.
The game is both CPU and GPU intensive. As well as it should be, in some areas, it looks like you're playing Crysis.
