Probably not.Hi, are the modular cables from the RM pin compatible with the HX line of PSUs?
Thanks.
Depending which exact model you have some are compatible with each other , check list below to confirmHi, are the modular cables from the RM pin compatible with the HX line of PSUs?
Thanks.
Yeah seems the only difference between those that use type 3 or 4 cables is that the ATX is different and all the rest is the same, i recently went from a AXi 1500 to a HXi 1200 ( both type 3 ) and used that chart to confirm as i am using a set of cablemod custom cables and worked no problem at all , took old psu out , new psu in using same cables and no issues at all, nothing gone bang and all working perfectlyFrom the charts, I just need to change the ATX power cable. All the others match. Seems like an easy swap out.
Thanks for the help.
I'm going from an RM750 to a HX1000 Platinum.Yeah seems the only difference between those that use type 3 or 4 cables is that the ATX is different and all the rest is the same, i recently went from a AXi 1500 to a HXi 1200 ( both type 3 ) and used that chart to confirm as i am using a set of cablemod custom cables and worked no problem at all , took old psu out , new psu in using same cables and no issues at all, nothing gone bang and all working perfectly![]()
