- 5 Dec 2010
- Solihull
Hi All
I Ordered an AM5 CPU and MB bundle from a Bolton based competitor. Board is an Asus Prime B650 Plus.
First board I ordered had bent pins in the socket. I took pictures, sent it back and the RMA went smoothly and I received a new board in about a week.
Second board looked fine, so I installed it in a case and added the other components. Then I discovered that the top M.2 slot wasn't working. The NVMe drive works fine in another slot. I have a picture of the socket from when I received and checked it.
Second RMA request raised. it took a lot longer this time for it to be processed or looked at, about a week. I was told that the board was physically damaged. They uploaded images to the order with bent pins in a socket.
The pins were fine when I sent it back. I reattached the socket protector when sending it and it was packaged sufficiently to prevent damage. In hindsight, I should have made a vide of me packaging up the item including the state of the pins.
I was told that because the board was physically damaged, that the warranty didn't apply. And that if I signed an agreement admitting fault, that they would send it to ASUS to see if it can be repaired.
I declined to sign the agreement because I'm not responsible for the damage. They said that the best that they could do is offer me a free repair, which I accepted.
Thoughts at the time were that ok, they'll replace the socket, test it, send it back. That's not not a bad outcome, as long as I get a working board. What this actually meant was they needed to ship it to ASUS to make the repair.
So far it has two months since I have returned the second board. I asked for an ETA but have been told that they can't give me one.
I have said that 28 days is the reasonable time for resolution according to the consumer rights act. They are just saying that the Consumer rights act doesn't apply because of the physical damage.
Can it be the case that retailers can just say there is damage, we have no liabiliy? Even if the damage has occurred during the RMA process after it has left my posession.
Has anyone else had a similar repair by ASUS and have an idea of how long it should take?
And any advice as to what actions I can take would be appreciated.
I can upload the images from both parties later if anyone would like to see them.
Thanks
Thanks
