Hey guys,
I was giving my pc a clean up today so as per usual i took everything out and then put everything in. Problem is that windows is not detecting my 6gb of ram. Only 1 stick of 2gb is being detected.
I took all the sticks out and tested one by one and they seem to be working ok. I also found out that only 1 memory bank is working on the motherboard, i.e. only 1 ram stick is being read. The other 5 do not work.
To add insult to injury after re-seating my cpu water cooler i found out that the cpu slot on the motherboard had some unusual looking pins, they seem slightly bent. I tried straightening them but i don't think they are ok.
Could the problem be due to that? or is there something else causing it. I have taken every thing out 3 times and put it back in but it has not worked.
Can i RMA the mobo? Right now last thing i want is to get a new one
Please help.
Please help.
