RoundCube Webmail - Help
16 Aug 2004
I have been trying to install RoundCube on my hosting and I have got as far as the login page which I can access by going to http://mydomain.com/roundcube
This brings up 3 boxes: username, password and server.
I have no idea what I need to enter in these boxes to login :rolleyes:
The only username and password I have setup so far is for the database.
Any ideas?
Roundcube basically acts like a web based IMAP client.
So you'll need to setup an email account via your hosting control panel - this is where you'll get your username and password from. The server you want to connect to will usually be yourdomain.com or mail.yourdomain.com
Thanks for that worked fine and also solved another problem I was having.
I couldn't send emails because I was entering mydomin.com instead of mail.mydomain in the server box
Cheers
Ste
