Primarily gaming on the 3080 (bought with mining profits from 2018 ) but also clawing some of the cost back when not gaming.
1080ti is mining 24/7 though.
100c isnt bad with all that gear in it!
Im waiting for the thermal pads for the 3090 before I squeeze back up the memory clocks and it has reasonable cooling in the case.
Even with a sink+fan on the plate soon as I push above 100MH/s the mem temps go over 100c. It is in a case so unless I bring down ambient (like opening the nearby back door) I think only the pad mod will get it properly under control, they must have been stingy with the pads on my card.
Core is on a curve about ~900mhz memory is only +100.
Ek active backplates 135 euro
https://www.ekwb.com/news/a-new-cla...kplates-for-rtx-3080-and-3090-reference-gpus/
when they go to the expense to build a cooler like the FE has you'd think they wouldn't cheap out on the pads.
The gelid ultimate is a harder pad so probably more similar to the odyssey than the gelid extreme.It is interesting to read out there the various iterations of pad thickness but I seem to note that with thermalright odyssey pads, it is 1.5mm all round due to not much leeway in compression. However with gelid GP extreme it is 2mm front and 3mm on backplate as there is some compression to be had. Interesting to note that gelid have also come out with a higher mk/W version as the gelid ultimate but they only come as 0.5mm and 1mm.
Im just waiting for thermalright TFX paste to come before I do mine, but I'm going for gelid GP extreme with 2mm front and 3mm on back.
What thermal pastes have you guys used?
Used kryonout paste on my 3080, not an FE model but stock stuff was rubbish and all watery. After replacing with kryonout the GPU die temp dropped around 6C and the VRAM around 30C using the ultimate pads.
