- 23 Jun 2018
- Leicester
Hope this is all sorted soon, fed up with my snail 1080ti.
I tried playing around with different voltages and it was still no go.See if you can cap the gpu voltage at like 1.05v or 1.075v at 2080mhz and see if thats stable, might not end up being able to boost that high.
How high can you get the clocks though?.Weird one for me. Gaming stability is perfect. I've thrown everything I can at the card to make it crash under stress and it doesn't.
But the driver crashes occasionally while playing back video in MPC-HC or MPV.
Website says: "MPC-HC is not under development since 2017. Please switch to something else."
Try VLC.
My copy of MPC-HC has a build date of Sep 19 2020, version 1.9.7.55Website says: "MPC-HC is not under development since 2017. Please switch to something else."
Try VLC.
I'm still not really buying the capacitor side of the story - this use of capacitors is generally a cheap and reliable way of hugely increasing your stable operating margins and is usually massively overkill - it is possible the crammed PCB or some other factors make a difference here or someone has really screwed up the design and the voltage regulation is easily destabilised.
Either mixed silicon quality or a bug in the boost algorithm is more likely IMO.
Get the cards put under a scope isnt easy. You need the scope and open bench setup and know how.
no one has the circuit board design so it is a guess as to where you stab the contact. But buildzoid has identified a couple of contacts look like a good start.
anyway I think the reviewers don’t have expertise or don’t want to go into this level of technicality for whatever reasons ( maybe cheesing off their financial sponsors). Then the average Joes who have cards and just don’t have a clue. Or someone maybe have the card and does have a clue but frankly cba with it all as not wanting to void the warranty of the card.
Let’s face it, if you paid for the card yourself you don’t want to void that warranty by ripped your card apart and start probing it. Even if you are wealthy beyond imagination, it’s not like you can get another card readily atm if you damage it.
I don't think that anybody, as long s/he is not an hardware engineer, knows about power delivery networks and additionally about the 30x0, can properly comment on this topic and say what the best constellation is to avoid the problems we see.
https://www.techspot.com/downloads/4411-media-player-classic-home-cinema.htmlWebsite says: "MPC-HC is not under development since 2017. Please switch to something else."
Try VLC.
Going from 2000 > 2100 is a gain of 2 fps so not a big deal although it could be an issue for those who want to water cool and will see higher clocks due to lower temps.Not sure if someone else had mentioned but Pauls Hardware did a pretty good video explaining at least his findings, wont link it just YouTube Pauls hardware
But it seems that the out of the box experience is fine, but when adding anything that pushes the card to far over 2ghz boost depending on the card you may see more boost or less but all cards including founders all crashed over 2ghz at one stage or another
benching Tomb raider 15 minuets game play.
You'll have to decided for yourselves if you think that is a good result or not,
I'm ok with it, the card I've bought will achieve the speed they sold.
TBH you could chase your tail speculating on this.
What seems to be a common factor is if the GPU clocks to above 2ghz it pushes into instability. You can downclock your card if you have an issue and it will work fine. I would surmise that the answer from nvidia or AIB's will be either a bios or driver release to sort.
I would say that is probably more down to the silicon lottery than anything else, but everything plays a part.
AFAIK even the highest clocked AIB's only specify a boost of around 1815 so technically you have what you paid for as long as it will do the specified boost reliably.
People asking should they cancel ... I would say not, just adjust your expectations of clock speeds. seems most cards will game around the 1900 area quite happily, and still be faster than what it replaced.
