- 17 Oct 2025
- UK
Hi,
Looking for advice on an RTX 4070 showing artifacting mainly in Apex Legends.
Symptoms:
What I’ve tried:
Results:
Temps:
Symptoms:
[]RGB/checkerboard artifacts
[]Mostly in skyboxes/light sources/rocks
[]Gets worse the longer the card is under load
[]Desktop, videos, and browsing are fine
[]Used to happen across the whole game, but now with the things above now mostly limited to sky/light rendering after troubleshooting
[]No crashes or BSODs
What I’ve tried:
[]Reinstalled Apex
[]Deleted Apex shader cache (psoCache.pso)
[]Cleared DirectX shader cache
[]Used DDU in Safe Mode
[]Installed latest NVIDIA driver clean
[]Reset NVIDIA settings
[]Lowered texture streaming budget to None
[]Lowered graphics settings (turned of GPU Accelerated)
[]Disabled some rendering features
[]Tried different fan curves- Tested VRAM underclock (-502 MHz in MSI Afterburner)
Results:
[]Clearing shader cache and lowering texture budget helped a lot
[]VRAM underclock cut artifacting roughly in half
[]Stronger fan curve didn’t help
[]EA FC 26 was mostly fine aside from one quick artifact in a menu however did produce the highest Temperature Hot Sport and Average temperature
Temps:
[]GPU (Idle - Desktop): 45–50°C
[]GPU (In Game): 72–80°C
[]VRAM junction: 68–74°C- Hotspot was around 92°C before, now hitting 105.7°C max
Trying to work out if this sounds more like:
[]hotspot/contact pressure issue
[]unstable VRAM
[]Apex/driver issue
[]or early hardware failure
I’m not fully convinced the GPU is dying since:
[]normal desktop/video use is perfect
[]fan curves, settings, and memory clocks clearly affect it- other games seem mostly stable
Any opinions from people familiar with RTX 4070 hotspot issues or Apex artifacting would be appreciated.
I’ve tried troubleshooting using AI but I can’t fully rely on it so I thought I’d ask here. My PC was bought about 3 years ago but I can’t remember where.
