Hi , looking for some feedback on my gpu temps
I installed a bytski full block with active backplate on a gigabyte rtx3090 gaming oc
Really happy with the memory t junction tems (48 under load) gpu overall temps sit at around 68 at load which again is not bad , but the gpu hotspot has bwtween a 15 and up to 20 delta vs the gpu temp, so if gpu is showing 65 the gpu hot spot is about 83 to 85.
Im pretty happy as quiet running is what im after, but was wondering if the delta was to much and perhaps the gpu hotzpot is a little high ? Perhaps not enough contact with the plate ?
