I am using the EK Vector Strix block with EK active backplate. as for the pads i just used the same sizes as EK state to use which is a mixture of 1mm, 1.5mm and 2mm so to do the card properly cost a bit as you have to buy 3 different sizes and a few packs of each to have enough for 1 card let alone 2 ... the pads are harder but had no issue with getting the blocks sandwich together , well no more than if trying with the ek pads ... its bloody tight but does 100% fit
https://i.~ibb.co~/NWqfNdk/20211115-185902.jpg
http://<img src="https://i.~ibb.co~/NWqfNdk/20211115-185902.jpg" alt="20211115-185902" border="0" />
Holly molly that is one nice water cooled setup, nice job
) . some don't like distro plate as they seem to think its set in stone with routing which it is to a degree but can still get creative and do many different configurations
