Running 2 clients on 1 pc
15 Jul 2008
SMP Client
Ok I have it installed and click teh .bat file and enter
account - Sheldon
Passwrd - Bobby
Confirm password - Bobby
now instead of getting
At the end of the install process, you should see two lines of output:
If you see this twice, MPI is working
I get
Unable to connect to Sheldon-PC8676
Sock error:generic socket failure, error stack:
MPIDU_Sock_Post_Connect<1228>: Unable to connect to Sheldon-PC on port 8676, Exhausted all end points <errno -1>
Any ideas?
You need to provide it with proper credentials, as Biffa says, it needs to be a local user account or any account that has admin access to that machine.
You also need to run that CMD console as an administrator before starting install.bat
