How much slack would you recommend leaving at the patch panel end?
Can I cross electricity cables at all? Seems impossible to me to route the cables without doing so at some point.
Any other tips?
Thanks
Always run more cables than you think you'll need (even if you don't terminate them).
I would use Cat6a as the new 10GbE will be out for the home in about 2 years.
Can the RJ45 modules be reused or once they're punched down, that's it? Stupidly, I have only ordered the exact amount I need and have never wired one before.
I wouldn't be so sure of that. Enterprise-grade 10 gig kit is still outrageously priced.
The new Intel 10GbE chip is $124 each but for some reason when put them on a card they charge in the UK £500+
But once mother board makers get a hold of them the price will drop a lot, we just got to wait for 10GGbE home switches.
