Ryzen 5 3600 with MSI B450 TOMAHAWK - cooler suggestions pls
7 Sep 2012
Lancashire, England
I have a thermaltake versa h18 case with two 120mm fractal fans in the front as intake and two CM master fans at the back and top for exhaust.
Its the 2600 but i dont think the 7nm 3600 would be hotter than this. It does a pretty good job. The stock cooler goes to about 75 so this brings it down a lot on load. I can test any particular application as well if you would like like 3D Mark or PC Mark.
The Ryzen 3000 series does run a bit hotter than previous chips from what I can tell after reading various posts to do with heat, voltage and boosting. My i7 6850k (14nm 140W) ran cooler than this chip, and Broadwell-E isn't exactly known for it's low temps.
I am using a Nocuta NH-D15S with my 3600, it never dropped from max boost clock at any load and stay below 60c even in stress tests.
May be a bit overkill?
I'm definitely thinking about buying a new cooler now. I'll be sticking with an air cooler though. I was looking at various Noctua models and the Dark Rock series from Be Quiet! The Scythe Mugen 5 looks like quite a substantial cooler for the price too. Basically I want an air cooler that will do a better job than the Alpenfohn Matterhorn Pure without costing more than say £80 or so. It's the first time the Matterhorn has let me down as I've used them with the i7 4790K, i7 6850K and a Xeon E5 1660v2... It never broke a sweat keeping these chips under control and that's with a low'ish fan speed tooo (around 1000rpm compared to 1500rpm with my Ryzen).
My Intel chips never went crazy hitting max boosts and voltages when just opening the browser or a new window either. I wouldn't be surprised if my Ryzen is hitting [email protected]+ just typing this.... :D.
22 Jul 2010
If youre open to an AIO I have an X62 Kraken and would recommend it, keeps CPU cool as a cucumber haha. And actually really helps keep air flow in the case good
12 Jul 2005
hey guys just resurecting this - the standard cooler is so loud and throttles up and down so im looking for something better.
Any surggestions for 2020? same spec as OP
Pet Northerner
Don
29 Jul 2006
Newcastle, UK
esports duo is still a great coooler and can be order directly from the manufacturer if stock is low in the uk.
They come from Germany but the last one I ordered took about 3 days via DHL with no customs.
6 Jun 2008
Finland
For 6/8 core Arctic Freezer 34 is bang per buck choise at "expensive" £21.
https://www.overclockers.co.uk/arctic-freezer-34-cpu-cooler-120mm-hs-077-ar.html
Alpenfohn Brocken 3 would be good step up for higher models.
https://www.overclockers.co.uk/alpenfohn-brocken-3-cpu-cooler-140mm-hs-05a-al.html
Scythe Mugen 5 would be also well priced near top level cooler and especially nice compact.
https://www.overclockers.co.uk/search?sSearch=mugen+5
But its optimized for monolithic die/centered heat source and oward concave heatspreader Intels and has convex base, which isn't good fit for Zen2's off center heat sources chiplet design and AMD's flattish/even smidge convex from center heatspreader.
Though that could be solved with some lapping.
https://www.igorslab.de/en/kuehlerb...amd-and-conkav-reader-test-and-picture-story/
