Ryzen 7 1700 typical oc on stock cooler
10 Aug 2018
Hi guys, but of a novice when it comes to building rigs but about to get a ryzen 1700 mainly for video editing. I'm not into water cooling and noise doesn't bother me so would like to keep the stock cooler. What's the typical overclock I can expect and what is the max voltage I can expect to run to cpu? Thanks
3.7ghz at 1.3v its probably what you wanna be doing, think max voltage is 1.45 but would most likely cause to much heat for the stock cooler.
