- 21 Jun 2011
Seems like the power of a 7600 with a much reduced price tag. Aside from being handy for debugging the iGPU seems just wasted silicon in a gaming build.
That was the post that flagged it for me - best I can find currently is ~105 plus 'expected £20 tax'.Upgrade advise - i7-8700 to what?
Big thanks to everyone. So it's looking like I should go for DDR5 6000 C30 ram, B650 board with a 7600/7700 with unless I can find a decently priced 7800X3D - this will give me a bit of a boost with the potential to upgrade to a 9800x3d in the future... perfectforums.overclockers.co.uk
yes but no.The shouldn't be any tax below ~£130. Not sure where the guidelines are.
I too thought this originally, but the the reasoning is to appeal to OEMs, where iGPU is adequate for desktop use.Aside from being handy for debugging the iGPU seems just wasted silicon in a gaming build.
How does it compare to the 5700X3D?ryzenj 7700 can be had for just under £150 if you look aroundthat's a much better buy.
its a little faster but not worth upgrading to 7700 if you own a 5700x3d not if you are primarily gaming and specially @4kHow does it compare to the 5700X3D?
I have a 5700 regular and I'm trying to figure out where to go from it. I'd like to go to AM5 but the X3Ds all seem a bit much.its a little faster but not worth upgrading to 7700 if you own a 5700x3d not if you are primarily gaming and specially @4k
RTX 4080, 4K
and mostly PUBG. I'm probably not CPU bound but just want a new toy
