I appreciate that I may be jumping to conclusions and that having only owned the car for 5 days you might say I'm being paranoid about the noise.
I have driven the car for at least 600 miles since I've had it, 200 of those being motorway miles. I feel this is enough time to know what sort of noise the gearbox makes in a healthy state. It would have a very slight whine in 1st and 2nd at low rpm. Nothing unsettling and sort of made it sound like a baby racing car.
Since the 'clear sound of bits breaking' incident occurred the noise the gearbox area now makes is extremely pronounced as I go up the revs, it is not me being paranoid. It sounds broken (perhaps a bearing) despite the mechanical feeling of the gear change not feeling any different. I can only imagine this would get worse and cannot enjoy driving the car anyway near the upper half of the rev range for fear of the gearbox seizing and causing damage to the engine.
It is a major job getting the new gearbox. As suggested, it is probably worth getting the fluids changed and taking a look at the existing fluids, though I am not confident this will improve things.
The reason I'm taking it to the Honda dealer is that I can get a discounted labour rate and secondly, the nearest decent specialist is 100+ miles away. This Honda dealer has done a number of engine swaps on the S2000.
