Samsung 1TB help please
7 Jan 2004
London uk
Hi
I have been running vista on my samsung 1TB drive for a few days, all was ok untill today all locked up and after reboot it will not boot from that drive, and the drive will not post in bios as if its not there Ive tried all different ways to get it to work no joy.Any ideas please
I have the same problem with my 500gb samsung spin point, vista sees it by bios doesnt see it in the boot menu, i think it is set to slave instead of primary master :) i wil have a look in a bit and then say how to fix it :)
Hi mate thanks for the reply, i have got it working i changed the sata input on the motherboard and it worked again:confused: Do you think there is a problem with the motherboard?I have never had this happen before.
Ati 3870
Mobo x48 gigabyte
4gb ram
intel 2.4ghz
