Samsung 2018 Q9F, Q8F, Q7F - differences and which to buy?
Man of Honour
28 Nov 2007
Hi, I'm moving my sony 1080p 49 incher to bedroom and buying a 4k 65 inch
Having gone into a couple of shops I am leaning towards the samsungs.
I like the single box for connections, small fibre optic wire, and flush wall mount solution with these and that would suit where I plan to install.
The salesman in one shop said the panel and engine for the Q8F and Q7F are exactly the same and that the main difference is a metal back to the 8F. Is that true? What else differs? It's quite a price difference if there is truth in that?
Does anyone have experience of this range? Is it worth the extra for the Q9F? Is the Q8F worth it over the Q7F? With the demos in store they all looked immense so hard to judge. The difference in price is £300 between each so approx £600 span.
It will be main TV in house, so gaming (currently xbox one and switch but will get one x), netflix, virgin and so on. I wouldn't say I am obsessive when it comes to picture but don't like obvious issues. Thanks for any input
Should if give you a little more detail. The Q9 is a true high end TV. Full-array backlight and FreeSync for your gaming needs has some of the best all-round input-lag.
It's great for dark rooms and bright.
It did suffer from over aggressive local dimming but I believe a firmware update has softened this.
OP buy an OLED far superior to any samsung LCD even the Q series from samsung. btw QLED is made up whereas OLED is an actual technology.
no an LG C8 OLED is
The reviews for Q9Fn seem pretty stellar and suggest they have addressed the issues from last year re QLED vs OLED? Isn't all tech jargon made up / marketing led to some degree? The LG seems great but I think that speaker bulge would be an eyesore on the wall and I don't even use TV speakers so would irritate me.
Thanks all for the input. It's caused me to do a bit more digging and I think the 9 is where I am headed not until mid-week though in case of any other input.
Q9 is the best I have seen this year. In the richer sounds demo room it was simply amazing, I preferred it to OLED myself.
I would get yourself booked into a decent opticians. Every review site worth a damn says different
Rtings
Avforums
Hdtvtest
You really do have such a strong view that your opinion is fact. I prefer it, and you cant tell me thats wrong. 10/10 reference status on the AVforum review as well, so not a bad TV.....
