Hi All,
Just wanted to run some questions past people regarding some issues I have been running into.
I recently upgraded my system to
7800x3d
Msi x670 carbon Wi-Fi
4090
Corsair DDR5
windows 11 pro
I also went for a 990 pro SSD this was back in August 23.
Initially everything has been fine and no problems but recently the machine has started -
Booting into bios - checking the hardware status it doesn’t pickup the 990 pro 2TB which has windows on it. Several saves and restarts resolves this, I did consider this a temperature thing potentially as the computer is located in a log cabin in the garden and temps can get low (lcd screen shows component temp at 3+ degrees in winter)
Incredibly slow booting time when compared to original install.
Windows loads and runs terribly - think PowerPoint presentation and you are in the ballpark.
These are all intermittent and do not occur constantly. Once the machine is running it’s flawless.
I had previously a 7950x cpu in it which I put in my sons computer it also did the same with that and since being in my sons computer has not done it again.
I am leaning to this being a drive problem but unsure really how to confirm without replacing it. Samsung magician says it’s “fine” but the behaviour suggests otherwise.
Anyone had any issues with their own 990’s
7800x3d
4090
Corsair DDR5
windows 11 pro
