samsung failing lba on smart test
23 Jan 2005
any help on this ?
(02) Samsung SSD 870 EVO 1TB
Model : Samsung SSD 870 EVO 1TB
Firmware : SVT02B6Q
Serial Number : S6PUNM0T205576V
Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : ---- (SSD)
Interface : Serial ATA
Major Version : ACS-4
Minor Version : ACS-4 Revision 5
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 364 hours
Power On Count : 351 count
Host Writes : 4454 GB
Wear Level Count : 7
Temperature : 33 C (91 F)
Health Status : Good (99 %)
Features : S.M.A.R.T., NCQ, TRIM, DevSleep, GPL
APM Level : ----
AAM Level : ----
Drive Letter : D:
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
05 100 100 _10 000000000000 Reallocated Sector Count
09 _99 _99 __0 00000000016C Power-on Hours
0C _99 _99 __0 00000000015F Power-on Count
B1 _99 _99 __0 000000000007 Wear Leveling Count
B3 100 100 _10 000000000000 Used Reserved Block Count (Total)
B5 100 100 _10 000000000000 Program Fail Count (Total)
B6 100 100 _10 000000000000 Erase Fail Count (Total)
B7 100 100 _10 000000000000 Runtime Bad Block (Total)
BB 100 100 __0 000000000000 Uncorrectable Error Count
BE _67 _57 __0 000000000021 Airflow Temperature
C3 200 200 __0 000000000000 ECC Error Rate
C7 100 100 __0 000000000000 CRC Error Count
EB _99 _99 __0 000000000008 POR Recovery Count
F1 _99 _99 __0 00022CD5271E Total LBAs Written
FC 100 100 __0 000000000003 Vendor Specific
SMART Self-Test
Model NameSamsung SSD 870 EVO 1TB
Serial NumberS6PUNM0T205576V
ResultLog #1OptionSHORT
StatusSuccessfully completed{0}
Power on hours
363​
Failing LBA
0​
Log #2OptionEXTENDED
StatusAborted by host{1}
Power on hours
286​
Failing LBA
81382400​
Log #3OptionSHORT
Power on hours
282​
Failing LBA
0​
Log #4OptionSHORT
Power on hours
281​
Failing LBA
0​
Log #5OptionEXTENDED
Power on hours
2​
Failing LBA
0​
Log #6OptionEXTENDED
Power on hours
1​
Failing LBA
1.61E+09​
Log #7OptionSHORT
Power on hours
0​
Failing LBA
0​
posted up, bought around 6 months back
Hmm, I think most of the problematic drives are 2021 or earlier.
Have you done a full scan with magician yet? Once you do a full scan, check crystaldiskinfo and change the format to decimal 10 from hex so you can read the raw values. If you have ecc errors and bad blocks in the raw values (or showing in event viewer) then you've got one of the faulty ones and need to RMA.
Thanks for the help, currently running a full scan, and will rerun crystal disk info in decimal 10, bought drive on 26/08/22
Thanks
Firmware : SVT02B6Q
Queue Depth : 32
APM Level : ----
AAM Level : ----
Drive Letter : D:
SMART Self-Test
ResultLog #1OptionEXTENDED
Power on hours
365​
Failing LBA
0​
Log #2OptionSHORT
Power on hours
363​
Failing LBA
0​
Log #3OptionEXTENDED
Power on hours
286​
Failing LBA
81382400​
Log #4OptionSHORT
Power on hours
282​
Failing LBA
0​
Log #5OptionSHORT
Power on hours
281​
Failing LBA
0​
Power on hours
2​
Failing LBA
0​
Log #7OptionEXTENDED
Power on hours
1​
Failing LBA
1.61E+09​
Log #8OptionSHORT
Power on hours
0​
Failing LBA
0​
Yes but it tested okay and I forgot about it, only posted this as I was going to add it to my unraid and wanted to test it first
If you did a full scan and the reserved/bad block and ecc error counters are still 0 then I think the drive is fine, or at least, it is not the common issue with these drives. They're usually showing errors before 5TB (which you've nearly reached) and lots by 10TB.
Well received the rma drive back today and just did a smart test on magician and getting the lba errors again, will be running an extended test then run it on a Linux test then see about contacting them again
If you take a perfectly serviceable Samsung SSD with no errors on it, start an "Extended SMART Self-test" (in Samsung Magician) and then stop it before it has completed, it will record a log with an "Aborted by host{1}" and "Failing LBA" message.
Now, whenever a Short/Extended SMART Self-test is carried out in the future, it will always bring up the red "Failing LBA" message in the top right hand corner of Samsung Magician. This is clearly a False Positive and there is nothing actually wrong with the SSD in this particular scenario.
I had already done this by mistake to several of my Samsung SSD's (all 500GB and 1TB 860 EVO's and one 1TB 870 EVO bought two years ago) and verified it today by taking a known good 860 EVO SSD without any faults and deliberately aborting the "Extended SMART Self-test". The "Failing LBA" message was now in the logs and came up on Samsung Magician every time I did a Short/Extended SMART Self-test. Upon further investigation of the logs, it had now added the "Failing LBA, 0" message to all the previous logs when 10 minutes prior, there were no failures recorded against any of the previous logs.
I am not sure if it is possible to ever get rid of the message once you have it but I intend taking one of the drives and trying several methods of erasure to see if the message will go.
Edited to add: I am merely showing that it is possible to get the "Failing LBA" message with a good SSD, however, you may be getting a genuine "Failing LBA" message in which case I would expect the S.M.A.R.T. attributes to show errors as well.
Needless to say, although my 1TB 870 EVO is running fine so far with no S.M.A.R.T. attribute errors (only the red "Failing LBA" message after I aborted the "Extended SMART Self-test"), I am now considering the likes of WD (Red/Blue), Crucial or another make for my next SSD purchases.
I had already done this by mistake to several of my Samsung SSD's (all 500GB and 1TB 860 EVO's and one 1TB 870 EVO) and verified it today by taking a known good SSD without any faults and deliberately aborting the "Extended SMART Self-test". The "Failing LBA" message was now in the logs and came up on Samsung Magician every time I did a Short/Extended SMART Self-test. Upon further investigation of the logs, it had now added the "Failing LBA, 0" message to all the previous logs when 10 minutes prior, there were no failures recorded against any of the previous logs.
Thanks I had running in Linux when I received it back to wipe all partitions then did a full format and when I put it back in windows with magician the error was gone and smart test reported nothing. Now running in unraid with no errors
My SSD's that are reporting the "Failing LBA" message are all in use at the moment. When I get the chance, I think I will carry out a Secure Erase on one and try a clean installation of Windows + Samsung Magician to see what results I get.
Update on my previous post:
I took a good 500GB 860 EVO that was reporting the "Failing LBA" message and did the following:
  1. Carried out a Secure Erase on the SSD (using ASUS BIOS).
  2. Clean installed Windows 10 on it.
  3. Installed Samsung Magician (current version).
  4. Viewed diagnostic logs.
And the "Failing LBA" message was still there.
I sent an email to Samsung Memory Support [email protected] with full details of the above drive that was getting the "Failing LBA" message.
They replied this morning with the following:
Thank you for contacting the Samsung Memory Support.
Please be informed that Failing LBA mean the location that test finished due to stop by user or scan failure.
If SMART self test complete without any error, failing LBA will be displayed "0" value.
So it means if the SSD all other test passed, without any issues, failing LBA is no issue of the SSD.
