240Hz at 5120x1440? Where's that bandwidth coming from? Would suggest DP 2.0 or more likely HDMI 2.1 perhaps.
I hope DP 2.0 will finally come to fruition in this monitor, as well.
But it would just be DSC, probably.
Or, maybe, Samsung engineers found a way to implement adaptive sync through a couple of DP 1.4 ports.
The 32" G7 is the one that interests me. Although the article states 2560*1440 Res in the Samsung link in the OP, I'm assuming that refers to the 27" model and that the 32" model will be 3440*1440?
With support for Gsync & Freesync it removes the tie to a single choice for GPU purchase - and with a 240Hz refresh rate, I don't think my 1080ti will cut it!
i'd expect the 32" model to be 2560 x 1440 as well. 3840 x 2160 @ 240Hz isn't an available or in production panel option at the moment
I was thinking it would be 3440*1440, why would anyone want a 32" 16:9 1440 panel?
If it's 16:9 then I wouldn't be interested. I also wouldn't be interested in the larger screen as who knows when a GPU would be available to push it @ 240fps.
The G9 I assume will be FALD to get 1000 nits.
1000R to me feels a bit too steep on the 32” and certainly on the 27” models. Can understand it for the 49” ultrawide more but on the others it seems a bit unnecessary
