Should have made it 3000R then you could wear its speakers as headphones!![]()
1000R to me feels a bit too steep on the 32” and certainly on the 27” models. Can understand it for the 49” ultrawide more but on the others it seems a bit unnecessary
Are they using some sort of dual DP 1.4 setup to achieve the bandwidth requirements?
Any ideas on what connection the 49" will be using B.A.? I'm guessing DP 2.0 is nowhere near yet so HDMI 2.1?
Who says it doesn't use DSC?
Has anyone found out yet, how Samsung achieves 240Hz native resolution 10-bit color, without any form of DSC? Because it exceeds what the current 1.4 DP bandwidth can handle (Samsung already confirmed that the monitor is running dual 1.4 DP, and HDMI 2.0).
Are they using some sort of dual DP 1.4 setup to achieve the bandwidth requirements? Or do you have to turn down the colors (Chroma subsample)?
Yep don’t expect any realistic 1ms G2G performance from these. Pure marketingThey may get close to it on the highest overdrive setting but then you've got overshoot to contend with.
Secretly hoping Samsung finally created a VA with reduced black smear.
