- 4 Feb 2011
Looks like the release date is potentially sometime this summer.
My dream monitor for the year.
****************************UPDATED BELOW WITH NEW INFO *************************
- If you switch between Mini hdmi or hdmi you will lose your calibration settings you changed on the monitor itself make sure you're using an HDMI 2.1 certified cable and you can set the monitor to up to 12bit colour (10 bit recommended for default calibration settings for now) same applies to display port but lacks the 12 bit option.
- If you have any jagged or pixelated text, do the below to try and fix the issue
select "No Scaling" or "Full-Screen" (I selected No Scaling). Perform Scaling on: select "GPU", select "Override the scaling mode set by games and programs">Size Tab: Resize the desktop...
: select "Enable desktop resizing", select "Do not report"It is only after this that my computer display/graphics were back to normal and I was able to open applications without fear that my text would go jagged/pixilated.
So if anyone here experiences the jagged/pixelated text, it may have automatically turned some of this stuff on. This should save you thinking you've got a faulty monitor.
- If you need calibration settings and ICC profile please pm me and I'll email you : or maybe similar settings are now available on google or reddit. I paid for access to them and donated a small amount so don't feel ok publicly sharing and denying the original user some form of compensation for their work, but if I share with less than 20 people he's not lost out, based on my original donation amount.
note that calibrating this correctly makes a huge change to the overall colour balance and picture quality across most games. Some games can still feel a little dull (Monza in F1 2023) but night races are incredible... so it's not perfect for every situation but it's vastly superior to whatever default settings you'd be running and of course you can tweak further for your own preferences, but it's a good base to start from.
- If you have flickering (I don't have a fix for this yet)
For those looking for settings, you can also try mine and check out the review here at TFTCentral
Samsung Odyssey OLED G95SC - TFTCentral
The new 49" super ultrawide G9 screen from Samsung, this time with a 240Hz refresh rate QD-OLED panel and 5120 x 1440 resolutiontftcentral.co.uk
