Samurize Scripts
i've given up already, got the program running etc, and put uptime, memory etc on desktop, but scripts won't load so i quit, cba with it
Hi,
Make sure you got samurize in c:\Program Files\Samurize
You'll need to make sure you got MBM running for the temps etc. Username, uptime etc need modding to use your computer name. Mail needs to be filled in by you, hotmail you need to be logged into hotmail with IE (not just MSN). news should work of its own accord. Weather needs your city code. Instructions for most the scripts are available if you open them with notepad.
Cheers
got the pc specs working, although i am having trouble installing the UKTV.vbs , i got the files and icons etc, just not sure what to add into the config :confused: anyone help?
Cheers
Hi,
OK kids here's the latest offering
What do you think of the TV listings - i'm not totally happy with it - doesn't quite fit in properly.
I also need a kewl TV icon to put up there too. I've emailed Foood and he's too busy to do requests, so has anyone seen any funky TV png icons?
A big thanks to Andy for modding the Coolmon TV scripts, helping me mod them further and hosting the file - Thanks Dude!! :D
Cheers
I spent about 2 hours trying to get various things to work but in the end just gave up with a really bad headache.
MTA99 - Any chance you could send or host the latest edit you've done above with the TV listings
Nice, looking pretty good,
Agree about the TV listings though, great to have the info, but it doesnt quite look right for some reason.
Good setup though!
Ok, the problem with starting on someone elses config is that you have a whole load of problems to do with where people put their scripts and what scripts they have!
In some cases, its easier starting from scratch as its really quite easy to set-up, it might take a bit longer, but your understanding of how the scripts work etc will be much better because of it.
does anyone know where to get packs of png icons? i've only got like 5 and would really like to sort the objectdock out. cheers :)
Originally posted by Jake
well, i've now given up, gone, end of story for me
It's not easy m8
I have a Computer Science Degree and am struggling to get to grips with it.
I can edit / use other people’s setups easily enough but creating my own seems impossible.
Hi,
I'll post the finished config when i get a suitable icon. Need to remove the black txt top left (refresh scripts).
Watch this space
Cheers
OK - I've taken out all the bits I didn't really need and re-designed the layout of what was left. Also added the infamous TV Guide. It still needs touching up a bit, and an icon for the TV guide, but other wise here is my latest desktop...
Andy.
HI,
Nice one mate - might have to take onboard a few of the design changes you made
I like it!
Cheers
