- 24 Mar 2013
- C-137
Please have a quick skeg at my watercooling basket; it's my first time getting my feet wet, and want to double check that I'm not going to run into any troubles, particularly with regards to fitting and tubing sizes.
I hvae made maybe 2 posts previously about going water-cooled, but had to put it off due to IRL things like buying a house and just generally being an adult .
But it's my birthday sunday, and the missus is going halfs with me
My basket at Overclockers UK:
Total: £373.41
(includes shipping: £11.10)
Also, ignoring the CableMod bits; is there anything I could save a bit of cash on and not loose much performance. Also, I have to ask, what should I use as a coolant, and would I need something like a kill coil in there?
Just realised that the pump/res combo is now out of stock. Recommendations on a replacement? I'd like to order today ideally so I can have a play at the weekend!
Thanks for your input!
- 1 x CableMod SE-Series KM3, XM2, XP2/3, FL2, XFX Cable Kit - Black / Blue= £69.95
- 1 x CableMod Basic Cable Comb Kit for SE-Series - Clear= £8.99
- 1 x EK Water Blocks EK-Supremacy EVO - Full Nickel (Original CSQ)= £69.95
- 1 x Hardware Labs Black ICE Radiator GT Xtreme 280= £73.99
- 1 x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump)= £107.99
- 1 x Monsoon 16/10mm (ID 3/8 OD 5/8) Free Center Compression Fitting Six Pack - Chrome= £24.95
- 1 x XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Clear/UV= £6.49
Total: £373.41
