**SAPPHIRE HD 7950 WHITE EDITION FIRST AT OcUK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Now the bad news, its an Apple ONLY product, but great to see that people with Apple systems can put a really high-end gaming graphics card into their Macintosh:-
Sapphire HD 7950 3072MB GDDR5 MAC Edition Graphics Card **APPLE ONLY** @ £399.95 inc VAT
SAPPHIRE Technology, the leading manufacturer and global supplier of graphics solutions based on AMD technology, has just announced an exciting new graphics accelerator compatible with the Apple Mac Pro series of desktop computers.
Exclusive to SAPPHIRE, the HD 7950 Mac Edition is based on AMD’s latest Graphics Core Next (GCN) architecture. This highly acclaimed architecture delivers a significant graphics performance boost for Mac Pro users in a wide range of applications including gaming, audio or video editing and content creation. For example, gaming frame rates are increased by over 200%, general benchmark performance increased by around 30% and graphics intensive benchmarks increased by as much as 300% compared with the NV 8800GT commonly used in these machines.
Specification:-
- Output 1 x HDMI (with 3D), 2 x Mini-DisplayPort, 1 x Dual-Link DVI-I
- GPU 800 MHz Core Clock
- 28 nm Chip
- 1792 Stream Processors
- Video Memory 3072 MB Size
- 384 -bit GDDR5
- 5000 MHz Effective
- Dimension 279(L)x110(W)x35(H) mm Size.
- 2 x slot
- Software Driver CD for Mac®, Driver CD for Windows®
- Accessory DVI to VGA Adapter, Mini-DP to DP Cable
- 2 x 6 pin power cable for MAC (250MM)
- Warranty: 2yr
Only £399.95 inc VAT.
ORDER NOW
I found out about this a while ago, it looks pretty awesome :)
It's a shame that there isnt a PC card that looks quite like this... I'm sure a BIOS flash would be possible, but that's just a tremendous waste of money :p
Oh I thought it was going to be a white PCB 7950, disappointed, as for one it's not by the looks of it, then to top it of it only fits Apple:(
Good for Apple users though, massive upgrade by the sounds of it for them:)
Works on OSX AND Windows from what I understand, has a bios switch, one side is EFI for OSX and the other is UEFI for windows.
Meh, where is the white PCB?
anyone could buy a standard reference 7950, strip the fan shroud down and spray it white for less than a tenner!
And as soon as the bios is dumped everyone with some sense will be buying standard 7950's and flashing them, am I right?!
Almost, most with sense wouldn't have paid out for the Mac Pro these are aimed at, most with sense would be running a less legitimate setup with the CPU and GPU of their choice ;)
Power Connectors look quite standard too?
Custom BIOS, custom drivers for OSX and a very small number will be made.
It's expensive, but so is the Titan and Ares.
But the Titan and Ares are special.
This as above is just a painted over reference card. It's already been made in large numbers just in a different colour :p
