Thank you Gibbo, much appreciated!![]()
Decided on the Be Quiet Power Zone 850w!
Thanks for the great deal on the Sapphire! will keep tuned on how to Overclock it!
290pro + waterblock is cheaper than the slower 780. Interested to see what Nvidia do with pricing now.............
This^
I'm guessing when he says sub £400 he means more than 5p to £5 less than £400. Maybe at least £20 or £30 less.
A week ago, you would have done well to find one at sub £500, so these sub £400 cards are welcome. Nvidia are not known for being cheap either. They are more your M&S with AMD being the Lidl of GPU's![]()
well after nearly a year with Nvidia it may appear I may be heading back to a Radeon again (only got rid of my 5850 a year ago!).
Just checked gibbos uniengine valley benchmark. My SLI 660 ti's only get 64.5 fps in the exact same test and our systems are pretty much identical.
Sell my 660 ti's and get a 290 pro and then add another one next month I think is the plan. However I'm pondering waiting for the non reference coolers as having two cards at 95 degrees Celsius in my Fractal R2 case might get a little bit toasty!
Enjoy your overpriced junk, I'll stick with Lidl thanksA week ago, you would have done well to find one at sub £500, so these sub £400 cards are welcome. Nvidia are not known for being cheap either. They are more your M&S with AMD being the Lidl of GPU's![]()
So basically 6% faster than a 780 for £70 less. Great stuff if you don't care about noise and heat, this seems very much like the gtx470 launch really. Looks like they'll need to go under water to really get them under control, especially if you want to get some nice clocks out of them 24/7. Hopefully more nvidia price cuts are imminent.
Where would my OC'd 7970 sit in those charts in the OP Gibbo? About the same as the 280 TOP?
