I have a little issue I'm hoping you can help me out with. I bought a WD SE16 320GB last week, after finishing the system build and installing Windows the OS is reporting it as a SCSI drive... as I have never dealt with such a drive before I'm not sure if this is OK or not, does SATA II share some of the same properties as SCSI?
Drivers were installed in the correct fashion (F6/floppy disk on install) and the JMicron driver added once the installation was complete. Curiously after adding the JMicron driver Windows started displaying the hard drive as being removable from the system.
Motherboard is an ASRock Dual SATA2 and things were running fine until a BSOD occured after changing the SATA II feature in the bios from IDE to SATA.
