[Scratch case] Project Duplex
11 Dec 2012
Hi,
So this is my new Project for the Cooler Master mod competiton. I still have a bit to design but will start fabricating soon.
It's called Project Duplex and will be a two faced case.
-On one side the motherboard, on the otherside a GPU and ssd's.
-Two seperate loops with a 240radiator each.
- WIll be made out of aluminum and acrylic
- Most of the watercooling will be hidden
Fabricating will start soon!
file.php
file.php
Ace
looking forward to this mate, that is a nice design :)
Thx buddy!
Great looking design. I must be being a bit thick, but how is the GPU going to connect to the PCI-E on the mobo?
With a pci-e "extension" cable :) There are cheap ones everywhere and then there are good ones which are quite overpriced, I'm hoping the cheap one will work, otherwise i will just have to fork out over a 100€ for the shielded one :s
At a guess - the same way the ssd's do - a cable
You are correct sir!
Looks like a cross between your CM Test Bench build & a Parvum! Very excited to see this finished. :D
Yes, There are things i don't like bout the test bench, so this is in one way a second chance :) Have seen the Pavrum a few times but never thought about it. (just checked their hompege) They do have a similar feeling and style :)
Sounds amazing, if I am valued to attach and input my personal opinion. :) :p
I love personal opinions :) As i said its not a 100% ready so i can always make changes if i get good ideas :)
Ooooo.. You're going to hide the cooling in between the ssd/gpu side and the mobo sides. This looks really interesting, I look forward to seeing how you do this.
This looks like a smart build with a nice twist on the cooling.
Looks very smart, my only comment would be to ask if you are planning on housing anything in the top section? As I would say it makes an otherwise very sleek design look a little bulky. Love the idea of splitting the components in half though very original!
My 1st thought aswell, I like it :cool:
Thx!
Thx! Yes, the radiators will be mounted between the sides in the front panel, The reservoirs is at the top corners of the case, can be seen in the pic :)
Thx man! The only thing that is there right now is a bay reservoir on each side. I do agree it looks a tad bulky but its symmetric now, i have tried so many shapes and sizes and in the end it looks best when its symmetric, at least i think so :) Maybe i can add more stuff to it?
Liking the look of this very original. looking forward to seeing the finished article and everything inbetween.
Thx buddy!
Thx man! The only thing that is there right now is a bay reservoir on each side. I do agree it looks a tad bulky but its symmetric now, i have tried so many shapes and sizes and in the end it looks best when its symmetric, at least i think so Maybe i can add more stuff to it?
My initial though was something along these lines:
Excuse the terrible paint skills, Just an idea, you may even have already looked at.
Cant wait to see this progress though.
Subbed, your work is amazing, Ace :)
e: If you're feeling really fruity, could you try and tap into the PCIe slot from solder points on the rear of the motherboard?
Thx buddy!
Always welcome! :) :p ;)
