Finally an update! Was a lot harder to get the profile than i thought. Living in the country side has its drawbacks
First i would like to say a big Thanks to OCZ and Mr J. for believing in me and sponsoring me with a 256GB Vector drive. Will take some nice pictures of it as soon as i get it back. Took it to a place to make it fit the build a bit better. More on that in another update
The profile, Ordered 2mm thick profile but when i got it it was only 1,5mm. Oh well, would have been nice with 2mm for threading but 1,5mm will be enough.... i hope.
after cutting all the profiles with a hand saw and I milled them to the right angle and size.
De burring all the edges
All profiles except one
Welding it all together. Was too optimistic with the welding. I did not think it would warp as much as it did. All in all it was only a mm or 2 off but due to so many angles and lengths it looked so crooked I did not wanna use it.
Plan B: Cut off all the legs, straighten out one leg that was a bit warped. The rest were fine. Then mill all of the legs at once to make sure they are all the same length and straight
Decided instead of welding i would make inserts to bolt into the profile and into the base and top. This way it's easier to keep straight and also a lot easier when its time to paint. Should have thought about this before
Tapping the inserts
All done. Still need to clean up to get it looking really nice but will leave that until its time to paint
The base
Made a 2mm sheet and pressed it inside the profile, welded it and after milled it straight. If i can get another profile i might make a 45 degree cut instead. Would look a lot nicer.
Time for some sheet metal work. Sticking with 2mm aluminum. Don't know what this is called but it is very useful.
The panel is divided into 3 pieces for now while i work with the pieces. I might weld them together at a later stage. Still need to drill a lot of holes and cut some openings in them.
Drilled and getting ready to tap
Had to try a mobo on it. Case looks huge and it is a bit big but u think it will shrink a bit once i start adding things to it
Sponsored by
