- 10 Apr 2004
Cyber-Mav said:if you don;t like my comments then go hide uder your bed and don;t come onto these forums.
i speak from personal experience and i have a x1900xt and i can honestly say that driver wise and stability wise it is a load of crap compared to any nvidia card i have ever owned.
thats a truly unbiased opinion, and i doubt any other ati owner will drop the fanboyism and admit the truth.
not saying that ati cards are crap. but when put up against nvidia card you then realise that ati cards are crapper.
LOL!
Why are you using XP64? Oh yes you have 4Gb, Im not entirely convinced you even need that much, even when you showed a SS using 4 programs, well shut one?
Sorry mate, but thats a silly comment to say if I ever saw one, and the amount of absolute **** you post its unbelievable, contradicting yourself and even just spamming. You overtook me 2 months back, and you have 1k more post than me... Infact the stuff you post actually makes MSN discussion...
Using rthdribl, well, you use that often do you? I installed it once on a nvidia card, guess what happened! It BSOD'ed. Installed it on my X1900XT, using ATi Tool clock switching, it worked perfectly.
A normal user wouldn't be playing in window mode, even if they did they wouldn't know if it was performing correctly.
A enthusiast uses ATi Tray Tools and driver level overclocking with the services disabled and manual 3D switching with some profiles and it works a dam treat. Can't have different clock settings for different games on nvidia cards.
Infact, I could actually change the power profile so that a X1900 is less power hungry than a GX2.
I can do stock clocks at 1.325V, that cuts 6C off load temps, that must be 10-20W, ooh look, the same as a GX2.
Same for idle, 2D clocks down to 400/440, 1.050V and 30C idle from close to 40C, that must be another 10-20W, ooh look the same as a GX2...
Both my X1900XT, X1900XTX and my 9800 Pro have never ever ever BSODed on me. Not once, ever.
However, my 6800U and 7800GT were a different story, couldn't get through a week without a nv4_disp.dll failure.
For me to go back to nvidia they will have to do something very, very special.
But I doubt that as folding doesn't work very well on nvidia GPUs atm, because of the "bad" way nvidia designed them.
So im my book:
ATI - 3 Points:
1.Complete stability.
2. Folding Capability.
3. Software controlled voltages.
Nvidia - 1 point
1. Cooler and use less power, oh whoop-di doo.. (im not fussed by noise and power)
Thats my opinion!
Edit: The OPs problems could be caused by the differences in BIOS version on the two cards, if all else fails flash the Asus to a His XTX BIOS?
CR.
