Hello.
I bought a new motor yesterday, a 205 1.8 TD 'Mardi Gras'.
The bodywork is in a very good condition for it's age and so is the interior but there are a few little problems on the mechanical and electrical side of things.
First of all I have to floor the throttle for it to come on boost. Should it be doing that? I was expecting it to be more like the 306 DTurbo but faster because of it's weight but it seems to be the slowest car i've owned so far.
So I'd like to put extra fuel into it before boost by adjusting the boost compensator screw like I did on the 306 if that's possible and maybe later on up the boost and fuelling. I'll be ordering a replacement 'performance' air filter for it to let it breath a little better too.
The second thing is maybe suspension or engine mount related i'm not entirely sure. The bloke I bought it from reckons it's the anti-roll bar bush which he's sending across in the post when he gets it, so we shall see about that one.
But I think it may be the engine mount because it has knocked when changing gear and when I turn off the engine it knocks.
And one other problem. The offside brake light will not work, I've tried a new bulb and cleaned the connection but it still doesn't want to work. Any ideas on this one? Also the offside spot light won't work either...could this be related to the brake light - bad earth?
Screw mod jokes not wanted, I just want a little more ooomph low down the range without having to boot it!
Thanks in advance!
Oh yeah. Other mods planned:
GTi brakes
Stiffer shocks and maybe lower it slightly (just a lil bit, maybe 15mm?)
Thanks in advance!
GTi brakes
