can u post some picsaphex said:Fits in my Aurora fine![]()
brenkehoe said:barney u play uo ?
i dont like the sound of thatbarney said:like i said though watch your figures![]()
bbreezeuk said:
oh look you also have to pay £8 delivery on the freezer 64 Pro which makes it £28 not £15Cyber-Mav said:£8.50 delivery? or do you get free delivery?
u know its goodnick_lerwill said:what bout the si-120 looks v good
sagaboy2 said:I had to original arctic freezer 64 then upgraded to the scythe ninjar well tbh its kinda a little waste of time and money.
Maybe dropped like 4C at max and the fan that came on the freezer was actualy quieter than a 120mm amber.
Maybe it will increase performance as the AS5 settles in again but atm it seem a lot of money to spend for 4C drop in temps plus it weighs a bit and stops me using my first DIMM slot![]()
TaKeN said:Well ive swapped the Ninja fan, for a 116cfm Panaflo 120mm
So im impressed with my new cooler
The Tuniq Tower 120 is better. Rare in the UK, but I've one coming £33.Cyber-Mav said:scythe ninja is the best air cooling solution your gonna come accross.
TaKeN said:Hmm, i just fitted a ninja tonight
Room @ 24oc
Full load Temp 48oc, got to 50 once,
Do these seem bad temps to anyone ?
I think they are pretty good considering room temp and my cpu having 1.6 Volts through it![]()
u must have a bad stepping 3700 to be shoving that many volts through it to achive that overclock, nice system specs thoughMeddlE said:Hmmm, same CPU and similar overclock, case temp at 21, idle at 32, full load at 40.
bbreezeuk said:u must have a bad stepping 3700 to be shoving that many volts through it to achive that overclock, nice system specs though
fornowagain said:The Tuniq Tower 120 is better. Rare in the UK, but I've one coming £33.
http://www.xbitlabs.com/articles/coolers/display/tuniq-tower120_8.html
