Scythe Ninja Plus
The gigabyte rocket pro are pretty good
I got one and i hit about 46'c full load at 2700mhz with 1.6vcore
Thats with room temp at 23'c.
EDIT: saying this though, although i am happy with the cooler i've got, i wouldn't have minded a scythe nina. But due the msi decideing to put the cpu socket right next to the agp slot on the neo plat 2 i am a bit restricted to space, especially considering that i've got a artic silencer on my gfx card.
How big are they, are they any wider than a rocket pro?
I dont mind taller as i have a big case, it just can't be any wider :(
The dimensions of it are 131 x 108 x 153mm (W x H x D).
EDIT: Was going to post pictures of it but they have got the websites name on them.
So I take it you guys would recommend this for some serious cooling going from a little akasa AK860?
Does the Ninja come with backing plate?
Will it fit on an Asrock Dual Sata?
How much louder is it and how many degrees did it knock off ? mine is currently running a 3700 at 2.7 at 47 under ful load with the stick fan, and i agree, its a ****ard to fit, though i was going to brake the board!
Louder than what? It's quiet, although I'm beginning to wish I'd bought a fourth turbine to replace the stock fan with. The quoted figure for the stock ninja fan is 23.5dba.
