seagate 2tb problems fixed now?
13 Mar 2010
anyone know if the problems on the ST2000DM001 seagate 2tb hd are fixed now? ive been reading about clicking noises when it spins up and failing with 3 platters or something?
i see OC has just got them back in stock which means they will have the newest version right with the newest firmware?
No clicking noise with my ST2000DM001-1CH164. I used that as an OS drive for around 18 months, no clicking at all. Currently has 15,090hrs on it and it's still running perfectly (runs 24/7).
Now my ST3000DM001-9YN166 had clicking noises every 10mins when I had it, sounded terrible. A firmware update (CC4H) fixed that issue a long while back, I think that was also supposed to fix any clicking noises on the 2 TB but mine was fine. That drive currently has 20,405hrs on it, also runs 24/7 and is running perfectly.
I just bought a new ST2000DM001 to replace an old external Samsung F1 1TB that has 41,000hrs on. This one also runs very quietly.
I would have thought so. My mate bought one that had this problem 2 years ago and replaced with one that did the same. He installed it and it still is working fine. I have used hundreds of them with little to no issues.
Nah its still clicking on startup but functions perfectly. He isn't bothered. Like I said I have not had this issue and I use those particular drives daily.
ok guys, ive ordered and awaiting delivery from oc ( ST2000DM001 ), i will flash it with the newest firmware when i get it installed and let you know how it goes.
