Seagate Pushbutton Backup 300GB External Firewire/USB 2.0 8MB problem
11 Jul 2003
Telford//west mids
My daughter took my usb cable from this hd the other day to use with her printer,today i fire up this drive and get a error from windows saying there is a problem,im thinking the cable has been damaged some how,when i plug the cable into my pc hub the light comes on the goes off again after a few seconds.
Before this my drive always work fine.
Thx.
So far ive tryed it on the mb and usb hub and nothing,rung my daughter up and shes told me that her printer wouldnt work also,so it may be the cable after all,ive ordered one from the shop.
Been working fine for the last few months or so.
I`ll try the cable if not will RMA it.
interesting, whats the error your getting? as i too am getting a problem with my external hard drive when i connect and again i think it's the cable, i'l be testing out my other usb2.0 cable in a bit :)
check the pastic inside the cable plugs are not damaged, also check the pins have not come loose and that there no kinks in the wires.
I'd also try another cable first incase the drive is damaged
Update: well got a new cable today and still getting the error,looks like it`s gona be a rma for me and ive lost all my data :/
harris1986 any luck with yours m8?
When i had this problem with an external drive I ripped the bugger open and found a peice of metal was shorting the connection (sounds weird I know) but i removed it and worked fine ever since. :) Wouldnt suggest it if its still under warranty but mine wasnt! :D
Problem sovled got my hacking tools oot and took the hd oot and it`s ok,must have been the control board,only problem is my DS3 only has one ide.
Just waiting for DFI to bring oot their new conroe board`s now.
