Seagate vs Samsung HDD
5 Jan 2012
Hi i have a dilemma which HDD to buy for my new pc i have the choice between
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ / ST500DM005)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-081-SA&groupid=701&catid=14&subcat=
VS
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-257-SE&groupid=701&catid=14&subcat=
My hardware has everything needed to run any fo these drives but i don't have an idea which will be a better choice for me, which HDD is more reliable and faster ?
Which hard drive would you recommend me to buy ?
Doesn't matter, they are the same company now. :p
I've heard Seagates and Samsungs failing in equal amounts, so pick the one with the best price.
So i have the choice between
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ / ST1000DM005) [ HD103SJ ]
VS
Samsung offers 3 years warranty
Seagate offers 2 years warranty
Samsung total + postage = £73.69
Seagate total + postage = £74.69
The cheaper one - F3. It may say SATA II and have less cache than the Seagate but you won't see much difference as both spins at 7200rpm. And the extra year warranty is a plus too.
Both warranty is sorted by Seagate as Seagate has purchased Samsung's HDD sector a while back.
if it is longer warranty and cheaper then go with the sammy, if u have to get it replaced by seagate they will give you a barracuda.
personally i would go seagate
The cheaper one - F3. It may say SATA II and have less cache than the Seagate but you won't see much difference as both spins at 7200rpm. .
Having the same Spin speed does not mean the drives will be anywhere near the same speed ;)
Example
My 7200rpm 3TB seagate
My 7200rpm 1TB Samsung F3
