Seeking advice on my first PC Build (for music DAW, VR, MS Flight Sim 2020)
4 Nov 2020
Manchester
Hi All. Just joined the forum yesterday and this is my first post so be gentle with me ha ha! I'm looking to build my first PC. I have done a few minor bits on PCs in the past (installing RAM, swapping HDD/SDD and OS, that kind of thing) but never build a full PC and wouldn't mind the challenge as I'm now retired and can take as long as I like doing it. I've been reading up as much as I can online and watching youtube videos on how to build a PC, and it looks doable. The scary bits I guess are:
• will the PC light up when I finally press the ON button
• will I do OK tweaking the BIOS settings, installing the OS, drivers etc.
• If I fail completely then are there builders I can take it to to get it up and running.
Other concerns are:
• the possibility of parts not fitting (for example, I've read one or two cases where the CPU cooling fan blocked access to RAM slots) and I’m not sure how you can be certain about that until parts are bought and on the assembly table
• Motherboard BIOS needing upgrade to work with CPU (I saw MSI boards have a BIOS Flash button and USB port so you can do it without a CPU, but others may need a CPU in place to do that). I don’t really want to be flashing BIOS anyway if poss as it sounds like an area where I could get it wrong
• Faulty parts and how to identify where fault lies. With this in mind, I’m thinking that buying from one source as much as possible is a good idea (I used to work in Newcastle U Lyme and see Overclockers are based there so quite like the idea of taking my business to them)
In terms of what is prompting me to build a new PC I would say:
1. Music production. I make and record music (results can all be heard at https://soundcloud.com/mobbing_it_up if interested!). I want something that is good for audio production (and I gather single core performance is relevant her as well as multiple core). I’m coming from a low baseline and my current machine is doing OK but nearing its limit at times (it’s a ?2014 Lenovo H530 PC i7-4790 3.6gb with 12gb RAM and an Nvidia 1050ti GPU, and a cheap Asenno 1tb SATA SSD for OS and storage and that seems to work well. I keep my projects synced on OneDrive as I also use a similar vintage Dell 480 laptop to work on projects at times. And I keep the Cockos Reaper DAW software on a USB stick and move it between machines (so my custom stuff moves with me – I back up the USB stick to Onedrive at intervals)
2. Oculus Rift S VR. The headset worked with the H530 for a while but then stopped playing and I’ve an ongoing (fruitless) dialogue with Oculus over that. But I think the headset is fine, its just that it for some reason no longer plays with the H530 (which is entry level for Rift S anyway, and its possible my recording stuff could be conflicting, I have a USB Audio interface going, and a pop-up Softube Console 1 app, though the Rift S failure predates the arrival of the latter). When we’re not locked down, I fly gliders and want to use Condor Soaring in VR to keep in practice. Condor is not a demanding VR app I’m advised, and it worked OK on the H530 until the Rift S started playing up (it can’t hold connection to the DisplayPort)
3. The arrival of Microsoft Flight Sim 2020 and the upcoming possibility of using VR with it (though Rift S is not at front of the queue I’m hoping it will be enabled at some pint). It is this that makes me want to move the PC spec up from things like B450 m/board, Ryzen 5 3600, GTX 1060 Super (which I think would be fine for 1 and 2 above) to something using a Zen 3 CPU and 2060 Super GPU, assuming I can buy and install a Ryzen 7 5800X on a B550 m/board without having to flash a new BIOS.
Sorry if this is a long first post! I reckoned it was best to all out all the thoughts in one post than do it in bits. I’d welcome any thoughts and advice you might have as I’m just plucking things out of the air at present! Thanks in hope.
Mike
My current shopping list, for comment/advice:
  • LANCOOL II MESH PERFORMANCE MIDI-TOWER CASE - BLACK
  • Seasonic Focus GX 650W Power Supply, Full Modular, 80 Plus Gold, 90% Efficiency, Cable-Free Connection, Hybrid Silent Fan Control, 10 Years Warranty, Power and Performance | Black
  • ROG STRIX B550-F GAMING (WI-FI) (AMD AM4) B550 ATX MOTHERBOARD
  • RYZEN 7 5800X EIGHT CORE 4.7GHZ (SOCKET AM4) PROCESSOR - RETAIL
  • Scythe Scmg 5PCGH CPU Cooler Mugen 5 PCGH Edition
  • VENGEANCE LPX BLACK 32GB (2X16GB) 3200 MHZ AMD RYZEN TUNED DDR4 MEMORY DUAL KIT
  • GEFORCE RTX 2060 SUPER GAMING X 8192MB GDDR6 PCI-EXPRESS GRAPHICS CARD (would like more - maybe 2070 SUPER - as it's been suggested 2060 might struggle with MS Flight Sim thought online advice suggests it should be OK, and I have to limit budget somewhere!)
  • Crucial P1 1TB M.2 2280 PCI-E 3.0 X4 NVME SOLID STATE DRIVE
Hi
Your build looks pretty solid ut the b550 motherboard will need a bios update to take the 5800x. The motherboard you chose has bios flashback so this can be done without a cpu
You will have to download the bios and put it in a usb drive , insert it into the flash bios port and press the button. There are many guides online to show you how.
Ram should fit fine with the cpu cooler.
Hi
Thanks for those thoughts - very encouraging and i have spent days trying to learn about the various options! I've been tempted just to buy a cherished 2nd hand off ebay but a bit of me would feel cheated if i didnt have a go at building my own. I must be mad! :rolleyes:
Your welcome.
There are loads off guides but read the motherboard manual carefully it will walk you threw building a your pc and getting around the bios.
Don't overtighten things be gentle you can always add a little more if needed.
Good luck with your build.
Your welcome.
Fab and thanks again for the encouragement. After seeing the bun fight today to get a Zen 3 processor (on back order) I'm wondering whether i really need one that badly so might go for an earlier series CPU just so i can be cracking on with it!
Alpenfohn Brocken 3 for £30 is now top choise for CPU cooler.
https://www.overclockers.co.uk/alpenfohn-brocken-3-cpu-cooler-140mm-hs-05a-al.html
Besides having guaranteedly flat base without possible problems of Intel optimized convex base on chiplet Ryzens.
Crucial P1 is seriously overpriced QLC Flash drive.
TLC based WD Blue SN550 is £10 cheaper:
https://www.overclockers.co.uk/wd-b...-solid-state-drive-wds100t2b0c-hd-56l-wd.html
Thanks a lot for that info - very interesting and very helpful. Funnily enough, by accident, I'd replaced Crucial SSD with WD M2 SSD on my shopping (though it may not be quite the same spec you're suggesting). The fan is particularly interesting. Looking up the spec for both, the Scythe seems quieter at 14.5db while the Alpnfohn is 19db. HOWEVER, the Alpenfohn is shifting 103 CFM at max speed whilst the Scythe 73CFM. Also, the Alpenhorn seems to have a single 140mm fan against the Scythe 2 x 120mm fans. So - putting price/cost to one side - maybe the Alpenhorn is at least as quiet at equivalent CFM and with a 140mm fan working at a slower rpm its noise frequency is probably lower (better when making music as low frequency noise is less of a problem than higher frequency. I'd not even heard of the Intel convex base issue, so that's something new I've learned!
I've decided its not worth me getting caught up in Zen 3 fever (and delaying getting the build started) so have changed to a Ryzen 7 3700X and for the rest have gone for components that would allow me to upgrade to a Zen 3 at some later date should I find a reason/need to do that. I doubt someone like me will miss the difference in CPU power. I've also fallen in love with the Fractal Define 7 case as it seems quiet, adequate on airflow for me (I'm not going to be a super heavy gamer), I'm not bothered about RGB (case glass door will be out of sight anyway!) and I like having 5 USB ports at the front of the case as well as a bay for a DVD / Bluray writer should I decide to fit one at some point. SO the revised list is looking like this (I've done my best to check component dimensions fit in the case OK and spec data suggests they do, including a 750w PSU as part of future proofing). I'd be really interested to get any comments on the latest spec. Also, I used ************ to put it all together and wanted to ask for advice on how to go about buying. Can anyone advise on the safest way of doing it so that should anything be faulty I have as much buyer cover as possible. For example, if I buy it all through ************, does that make it safer? Or am I better doing to Amazon and getting it all through them so I have their buyers cover? I'm guessing that the worst thing is going to lots of different online shops to buy just because I'm looking for cheapest prices (and anyway, I can't seem to beat PcPartpickers overall price so far!). I'd welcome all thoughts :-) and my current proposed spec (for comments) is:
• Fractal Design Define 7 Compact Mid Tower Case
• Seasonic Focus GX 750W Power Supply, Full Modular, 80 Plus Gold, 90% Efficiency, Cable-Free Connection, Hybrid Silent Fan Control, 10 Years Warranty
• ASUS ROG Strix B550-E Gaming AMD AM4 (3rd Gen Ryzen™) ATX gaming motherboard (PCIe 4.0, NVIDIA SLI, WiFi 6, 2.5Gb LAN, 14+2 power stages, front USB 3.2 Type-C, Addressable Gen 2 RGB and AURA Sync)
• AMD Ryzen 7 3700X Processor (8C/16T, 36 MB Cache, 4.4 GHz Max Boost)
• Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
• Asus GeForce RTX 2070 SUPER 8 GB STRIX GAMING OC Video Card
• Western Digital Blue 1 TB M.2-2280 Solid State Drive
And thanks+++ again everyone who has helped. Look forward to hearing peoples views.
Mike
Yeah, smells of badpartspicker...
Zero sense to waste M.2 slot for SATA drive, which is as fast in end of the cable.
WD Blue is entirely different drive than Blue SN550 and no faster than 2.5" SSDs.
Zero sense to pay X570 board price from more limited features B550.
https://www.overclockers.co.uk/giga...4-x570-chipset-atx-motherboard-mb-57w-gi.html
https://www.overclockers.co.uk/msi-...-am4-ddr4-x570-atx-motherboard-mb-351-ms.html
This is proper pricing for B550.
https://www.overclockers.co.uk/msi-...i-amd-am4-b550-atx-motherboard-mb-35b-ms.html
https://www.overclockers.co.uk/msi-...i-amd-am4-b550-atx-motherboard-mb-35c-ms.html
RTX 2070 Supers seem to be horrenduously overpriced for outdated generation.
Heck, new Xbox has notable amount more GPU power!
Mugen 5 PCGH's cooling performance is compromised by low speed fans lacking pressure.
And convex heatsink base doesn't make good contact with flat heatspreader in correct places compared to location of heat production in chiplet/MCM Ryzens.
https://www.igorslab.de/en/kuehlerb...amd-and-conkav-reader-test-and-picture-story/
(last page has picture of what TIM spread should be when heatsink makes good contact with CPU)
This issue could have well been about that.
https://www.overclockers.co.uk/foru...-matching-or-beating-scythe-mugen-5.18902588/
so if you don't want to possibly lap heatsink's base, alpenfohn is better.
and lot cheaper...
with corona virus related problems there's no idea when seasonic is in stock.
phanteks amp is same psu in different clothing.
https://www.overclockers.co.uk/phanteks-amp-750w-80-plus-gold-modular-power-supply-ca-09r-pt.html
and lot cheaper...
Fantastic advice again and thank+++. About to have tea and I'm weary so will look at all this tomorrow. PCPartspicker is not the easiest for selecting the right bits (I'd not meant to select M2 SATA thats for sure!). I ended up on the B550 after reading reports that X570 board had fans that could be noisy? But otherwise, absolutely I'd go for X570 and thanks for that. Not sure what to say about 2070 Super as I don't want to be spending OTT for spec I'm unlikely to make use of and yet want to give MS Flight Sim a fighting chance if I do start fooling around with it (esp if/when Rift S VR becomes possible). Any alternative you'd suggest at similar price to my choice? Also, any thoughts on the best ways of buying the components so as to have best buyers protection if anything is faulty?
Thank you so much again - its a very steep learning curve for me and exhaustion starts to get the better of me, so your pointers are invaluable.
Mike
Asus screwed up big time in X570 chipset cooling... as in brand marketroids screwing consumers into rear:
Actual heatsink under marketing excrements is from tiny to small.
And relies on constant airflow from constantly running fan.
With everything positioned into worst place under graphics card to be bathed in its heat.​
So put there high heat output graphiucs card and chipset will be running warm and warmer.
And shouldbe easy to guess what happens if/when fan wears out.
Gigabyte and MSI have properly designed coolers with good size heatsinks farther from heat of graphics cards and mostly work passively.
Right now is bad time to buy new graphics card.
AMD's RDNA2 cards are going to be released for sale in 18th.
So with bad availability of semi paper launched Nvidia Ampere cards might be worth of waiting those.
and lot cheaper...
Hi again. Just working on your suggestions. Regarding the X570, I'd find built in Wifi and Bluetooth useful (better Wifi with aerials than with USB dongle?) so would this one do https://www.cclonline.com/product/2...ket-AM4-X570-Chipset-ATX-Motherboard/MBD2675/
Your other suggestion is Msi but isnt that the brand with fan issues?
Oh and any thoughts on the wisdom (or otherwise!) on getting things through PCPartsPicker (I note the Phantex CPU is much dearer via them but generally things seem cheaper) versus buying them all from various best price sources myself?
Thanks again for helping - it really helps!
Mike
For signal reception best kind of Wifi adapter would be external or one in which you can position antennas
https://www.overclockers.co.uk/tp-l...-6-bluetooth-5.0-pci-e-adapter-nw-21u-tp.html
That would help to avoid having PC case potentially in between adapter and access point.
Some of them are USB connected (like Asus USB-AC68) and in fact would be technically preferable to have USB cable to PC with antennas attached to adapter:
Antenna cables always attenuate signal some amount per length and you want to minimize distance between antenna and transceiver.
It's exactly brand overhype Asus which has badly designed X570 chipset coolers straight from rear end of marketroids:
Actual heatsink under marketing excrement covers is tiny.
With whole crud positioned into worst place directly under graphics card to be bathed in its heat.​
So add high end graphics card there and chipset will be fast running wamr/hot.
And should be easy to guess what happens if/when fan wears out.
Gigabyte and MSI have proper sized heatsinks farther from heat of graphics card and work mostly passively.
You are 100% right about the PC location blindsiding Wifi aerials at PC back from my router location! I notice also your Msi m/board suggestion has Wifi so might as well try that out and see how I get on and then resort to other add-ons if needed.
So, taking on board your various recommendations, the spec looks like this:
  • PHANTEKS AMP 750W 80 PLUS GOLD MODULAR POWER SUPPLY
  • MSI MAG X570 TOMAHAWK WIFI motherboard Socket AM4 ATX AMD X570
  • ALPENFOHN BROCKEN 3 CPU COOLER - 140MM
  • Asus GeForce RTX 2070 SUPER 8 GB STRIX GAMING OC Video Card [this is just a placemarker - see my comments below]
Regarding the graphics card, maybe I'd be best buying the other components and starting the build and then by that time the situation could have changed? Even then though, won't the arrival of the new GPUs you refer too only involve more £s to buy, either because the new ones will be dearer but also (as I saw on one youtube review) because it might push prices for older ones up as people grab stock to avoid paying for next gen stuff?
Unless you think its a bad idea, I think I might buy the parts from whichever source is either best looking price and/or has availability. Any thoughts on that?
I can't thank you enough for helping me with this. If we ever meet, I must buy you a drink!
Mike
Get the WD Blue SN550 m2 it's faster than the 2280.
Buying parts from one place can be handy if faulty and a place like overclockers offer fantastic support, but cash is king.
Hi again. Just sourcing the various items based on your thoughts. Hoping to get it all from Overclockers but sadly the GPU (which could wait, as you suggest) and both of the M/boards you recommend are out of stock there so I suppose I might have to source those elsewhere if I can (which kind of undermines the value of buying from one place but...).
I came across discussions showing concern over VRM temps on the Msi X570 board (one example is https://forums.tomshardware.com/threads/are-msi-x-570-motherboards-vrms-really-that-bad.3521489/ but there was a youtube video also discussing it) - is this an issue do you think esp since I'm not likely to be a super serious power user. I'd welcome your thoughts as ever & thanks. Mike
Deeply scary but the deed is done guys and thanks again so much for your help. I've a feeling I'll be back with questions when I start trying to build this beastie so hope that's OK. One question on my mind is all the different prices for paying for Windows 10. Any advice on the best route to take with this one. Also, whats the view on flashing BIOS. I'm guessing the MSI X570 Tomahawk will work out of the box with a Ryzen 7 3700X and I really don't want to risk flashing BIOS on my first PC build attempt unless essential but....
Oh and in the end I just bought the Gigabyte 2070 SUPER so I can get on with things because it seems a good GPU even if not maybe the best value for money as at today. Hope that doesnt raise too many frowns. And I went for the Fractal Define 7 case despite reports of limited cabling space unless I remove the HDD carrier. I can live with that (and lack of fan hub) as its an elegant case, cooling seems like it can be got adequate, and I really like having 5 USB ports accessible on the top plus a bottom filter that can be pulled out from the front, plus (a major one this for me) it is sound deadened so hopefully will be quite even though (maybe) the fans will have to run a bit more to cool things. The Define 7 (non Compact) just looked to bl**dy big for my liking, great though it was.
Right, time for tea and a stiff drink!
Mike
3700x should work straight away on the x570 motherboard but you can use the flash bios button on the motherboard, many guides and videos to show you how.
Keys should pay no more than £10 usually they email them.
