Hi guys. Only me again. Well, to quote the famous line from Frankenstein: "It's Alive" https://www.youtube.com/watch?v=xos2MnVxe-c&ab_channel=crawlfan
And she is ready (I hope) for the Great Windows Install, shortly followed by Drivers 4 You.
https://photos.app.goo.gl/sbGv1ataDPKEr85j7
Have to say the Define 7 is a lovely case, especially for my purposes (don't need lots of lights but want lots of USB ports, solid build with sound deadening etc). I bought a second 140mm fan for the front (Be Quiet brand, so its 2 x 140mm at front, 1 x 120mm at back, and the big 140mm on the CPU cooler) so hopefully it'll keep reasonable temperatures. For the PWM Be Quiet fan I used the PWM connection on the m/board that would otherwise be used for a water pump I think, so hopefully I can use PWM driven cooling profile in BIOS to control that. I was amazed when it lit up first time, have to admit to being nervous about that. And although lack of space for cable tidying was one criticism of this case in reviews, I found it fine.
So my questions now are about where to purchase Windows safely, legally and inexpensively. Also which flavour of Windows 10 to buy ( Home, Professional, should I update to the very latest issue etc). If anyone has any pointers on that I'd be really grateful. Also, advice on drivers. The X570 Tomahawk Motherboard comes with a DVD with drivers on it but the new PC doesn't have a DVD (though I have a USB connectable one if need be). But anyway is it not best just to go onto the MSI website and download and install latest drivers from there. With the The Gigabyte 2070 Super am I right in saying my best bet is to install GeForce Experience from NVidia and let it do whatever it needs to do? And regarding sequence, I'm guessing:
1) Install Windows
2) Install M/Board drivers
3) Install GeForce Experience and let it interrogate system and update as it sees fit.
Any help on any of this would be much appreciated and thank you again so much for all the help that has got me to this happy point.
Thanks again.
Mike
1) Install Windows
Thanks again.
Mike
