Having just bought a car a few of weeks ago for about a grand, I discovered a problem I did not notice on the test drive/initial inspection. There is no heat coming from the heater when the car is idle [e.g in traffic or so]. I took it in for someone to have a look at it, and after much investigation and testing it turns out that the cylinder gasket needs replaced [and possibly needing skimmed at the same time]. I was quoted £500-600, which is expensive. I have yet to get a second opinion on this but it leaves me in a difficult position...
Seeing as I was lied to by the previous owner who must have known about the problem, I must make a choice:
In either of the first two cases I will have to spend say £500ish.
Car is a Ford Fiesta 1.25 '97, 80k miles.
- Get rid of the car. Sell it for a few hundred [I have no idea what its worth now but a guess would be about £600-700] and get another second hand car.
- Get the head gasket fixed and continue to use the car.
- Leave the head gasket? (How dangerous would it be to do this? I never noticed anything wrong, just no heat as described above) The car is only used lightly - i mean less than 30miles a week i would say.
- Go back to the seller - can I take the car back and say that they sold to me under false pretenses? What if they say they didnt know it had this problem?
