Thank you again,There are other options that will get close, but none are as easy or as well supported.
Snapraid is a free option that will do "sort of" data parity on Windows https://www.snapraid.it/ but it requires a lot of configuration and isn't necessarily automatic
Stablebit Drivepool will help pool drives under Windows and can do file duplication/balancing https://stablebit.com/DrivePool/Features but again it's a paid for option
Windows Storage Spaces in Windows 10/11/Server will do Parity storage spaces, but I'd be hesitant to recommend it for any data you care about - like much of Windows 10/11 lately, it isn't well tested, and updates frequently change behaviour or cause issues
Note that while Unraid is the recommended option for ease of use and the benefits of the Unraid parity format, for Media RAID5 on any NAS operating system (Truenas/OpenmediaVault/Proxmox etc) is normally still a good enough option (it still maximises space whilst maintaining some degree of redundancy)
Not having any RAID/redundancy is also a valid option - ultimately it depends how big your media collection is, and how much you value your time if you were to have to re-rip/re-download it.
That's only relevant for RAID0 (Striping with no data protection), regardless of drive sizes RAID1/10 is still very much common, and RAID5/6 still has a couple of use cases.
Plex (or Emby/Jellyfin only transcode if the client doesn't support a format or something is set up wrong - e.g. you've manually restricted bandwidth somewhere).
If you aren't using Plex etc, then surely you are missing out on metadata (e.g. movie descriptions etc) and it must be a very basic experience
I guess Raid 5 would be the best option, most people use Linux for home servers (must be a reason) and since I want to get the most out of mine, ill be doing the same.
Which OS would be best for someone like, me who is using it for the first time like me, Truenas Core/Truenas Scale/OpenmediaVault/Proxmox etc
I'm thinking Truenas But I'm not 100% sure yet.
). Yep leave all drives including the SSD as separate drives and let openmediavault set them up
