- 24 Jul 2009
Updated to V6 last night. As I run it through proxmox, I had to disable NTP.
Any good? what's new?Updated to V6 last night. As I run it through proxmox, I had to disable NTP.
Ditto. A slight change to the UI here and there but otherwise appears to be the same visually and layout-ally.Seems the same to me. Few UI changes and there will be changes to the back end but nothing that has affected me.
Same here and have been running perfectly fine up until recently. Are your devices setup to point directly at pi hole or pointing to your router then to pi hole?Erm, four iPhones, three or four iPads and multiple Macs are all running through my Pihole(s) with no issues and default settings.
My Piholes run DHCP as well as DNS so the devices never touch the router.Same here and have been running perfectly fine up until recently. Are your devices setup to point directly at pi hole or pointing to your router then to pi hole?
Tried chatgpt?Googling doesn’t turn anything up, so it does point towards a me issue! I’m lost as to what it is though.
You are welcomeThanks Jonney….
I ran Blocky with Prometheus and Grafana for a while at the beginning of last year. I posted up my configs to run them under a single compose.yml if you're interested.Moved over to blocky. Impressed so far. Prefer the approach to config - it works much better when running as a container with docker. Much more portable and flexible. Bit more initial work to get setup but also a bit more control and performance seems great. Things I've had issues with on Pi Hole are working immediately. Going to try add more functionality incrementally, like query logging and DoH support and see how I go.
