Setting up Pi-hole
Okay, thanks. Well one of the websites I don't use very often is reporting I'm using an ad blocker so it must be doing something.
I am using a Pi 2W via Wifi, is there any point in getting a network port dongle? I do have one that has a USB-C connecter but it doesn't work with the Pi using a USB-C to micro sd converter, no power passing through.
I also don't suppose there's any point in adding the PS5 to Pi Hole, just things like computers, phones and tablets?
If I game on my PC will it add latency?
The only delay would be when performing name resoluition. A few ms isn't going to make one bit of difference to your DNS lookups, quite frankly. Once your device has performed the lookup, there will be no further delay. The short answer is no, this will not affect gaming on your PC, nor add any latency. To provide some further context:
Your client (PC in this instance) needs to connect to gameserver1.com (just an example). It will send a DNS lookup query to your Pi, with Pi-hole listening for DNS requests. If Pi-hole doesn't have the record cached, it will go to your configured DNS forwarder and query it for the record instead. Once it receives a response, it forwards the response back to your client (PC). Your PC then makes a direct connection to whatever gameserver1.com resolved to. The Pi is no longer involved once your client (PC) knows what IP address to connect to.
To flow it:
Client > Pi-hole > Check Pi-hole cache, if no cached record, do lookup > Pi-hole sends DNS query to DNS forwarder > Pi-hole receives response from DNS forwarder > Pi-hole sends response back to client.
Client connects directly to the resolved IP.
To flow it:
Many thanks good sir. Shame VM won't allow modem mode on thgeir newer hardware, but I guess Pi Hole is working as intended so all good.
Yes, very good indicator if a website is telling you that you're blocking. If you haven't already, have a look at Hagezei (https://github.com/hagezi/dns-blocklists) lists. The default StevenBlack list is good for basic blocking but they take it to another level.
If you can, rework your network so your Pi is cabled in. If for whatever reason the connection to the Pi isn't greatm your whole network will suffer. I wouldn't want critical infrastructure to my (or anybodies) network connected via WiFi - Cable is the way.
Run everything you can via your PiHole! If you use more feeds, you're protecting the devices using it, not just ad's, Hagezei does threat feeds, it's an extra layer of protection you can bake in with zero effort for other clients.
I looked at that but don't know how to add it? I added Easy something as that was just copying and pasting a line of text. I have found the Pi Hole links and wehen I click on either Link/M1/M2 it gives me a big list so I guess I just need copy the the link from the address bar and paste it into Pi Hole with the other 2?
Also after approx 24 hours I've had to reset my VM 5x router, nothing would connect and my Xbox showed could not connect to DHCP server although everything has been working fine for around a day?
What's the situation with letting cash back sites such as topcashback, Quidco etc to not get blocked?
I imagine the URLs/IPs change dynamically
If I'm on my phone I just turn WiFi off and use mobile data instead with ublock disabled in browser.
Anybody using dnscrypt-proxy with pihole for DoH, if so how do I setup quad9.
I tried adding quad9 in the following line
# server_names = ['scaleway-fr', 'google', 'yandex', 'cloudflare']
Example:
server_names = ['quad9']
the cloudflare seems to work ok......
Code:
● dnscrypt-proxy.service - Encrypted/authenticated DNS proxy
     Loaded: loaded (/etc/systemd/system/dnscrypt-proxy.service; enabled; preset: enabled)
     Active: active (running) since Thu 2025-11-20 12:52:47 GMT; 3s ago
   Main PID: 2135 (dnscrypt-proxy)
      Tasks: 10 (limit: 8750)
        CPU: 131ms
     CGroup: /system.slice/dnscrypt-proxy.service
             └─2135 /usr/local/sbin/dnscrypt-proxy -config /etc/dnscrypt-proxy/dnscrypt-proxy.toml
but if i try quad9 I get...
     Active: activating (auto-restart) (Result: exit-code) since Thu 2025-11-20 12:50:32 GMT; 52s ago
    Process: 2100 ExecStart=/usr/local/sbin/dnscrypt-proxy -config /etc/dnscrypt-proxy/dnscrypt-proxy.toml (code=exited, status=255/EXCEPTION)
   Main PID: 2100 (code=exited, status=255/EXCEPTION)
        CPU: 120ms
The term quad9 isn't a known label for any DNS service. If you check the upstream list of DNS servers, the one you want is probably one of:
Code:
quad9-dnscrypt-ip4-filter-pri         # Quad9 DNS, no ECS, malware filtering, dnscrypt protocol
quad9-doh-ip4-port443-filter-pri      # Quad9 DNS, no ECS, malware filtering, DNS over HTTPS protocol
If you update your config with one of those and reload/restart the service, you should find it works.
Code:
Thanks for that.
Code:
     Active: active (running) since Thu 2025-11-20 16:47:19 GMT; 6s ago
   Main PID: 2732 (dnscrypt-proxy)
        CPU: 162ms
             └─2732 /usr/local/sbin/dnscrypt-proxy -config /etc/dnscrypt-proxy/dnscrypt-proxy.toml
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] Network connectivity detected
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] Now listening to 127.0.0.1:5053 [UDP]
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] Now listening to 127.0.0.1:5053 [TCP]
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] Source [public-resolvers] loaded
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] Source [relays] loaded
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] Firefox workaround initialized
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] Hot reload is disabled
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] [quad9-doh-ip4-port443-filter-pri] OK (DoH) - rtt: 22ms
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] Server with the lowest initial latency: quad9-doh-ip4-port443-filter-pri (rtt>
Nov 20 16:47:19 fireping dnscrypt-proxy[2732]: [2025-11-20 16:47:19] [NOTICE] dnscrypt-proxy is ready - live servers: 1
Much appreciated.
Does setting up pihole block adverts on the TV, got a LG one for the parents and plauged with adverts everywhere.
Have you turned nearly all of that nonsense off within settings first? There are a surprising amount of options for controlling adverts in WebOS. They're disguised as "personal recommendations" and crap like that.
A Note To Myself pihole+cloudflared on portainer on rpi4 64
Heads up if you use Pi-hole with DNS-over-HTTPS via cloudflared.
Cloudflare have removed the old cloudflared proxy-dns feature from newer versions of cloudflared. If your Pi-hole is configured to forward DNS to 127.0.0.1#5053, and cloudflared updates to a new version, DNS can partially break.
The awkward bit is that Pi-hole may still look healthy. The dashboard can still show queries, blocked domains, active clients, and normal-looking graphs, because Pi-hole is still receiving requests and can still block domains locally. But normal allowed lookups may fail or time out because Pi-hole is forwarding them to cloudflared on port 5053, and cloudflared is no longer running that service.
Quick checks:
On the Pi-hole, run:
grep -n "^PIHOLE_DNS" /etc/pihole/setupVars.conf
If you see:
127.0.0.1#5053
then check whether anything is listening there:
sudo ss -lntup | grep ':5053'
If nothing is listening, DNS-over-HTTPS is broken and Pi-hole’s upstream resolver is dead.
Also check:
systemctl status cloudflared --no-pager
If the log says DNS Proxy is no longer supported since version 2026.2.0, that’s the problem.
The simplest fix is to stop using cloudflared for Pi-hole DNS and set Pi-hole back to normal upstream DNS servers such as Google, Quad9, Cloudflare, OpenDNS, etc. In the Pi-hole web interface, go to Settings → DNS, remove 127.0.0.1#5053, choose normal upstream DNS servers, save, then disable cloudflared:
sudo systemctl disable --now cloudflared
Then test:
dig @PIHOLE_IP google.com
If that returns an answer instead of timing out, it’s fixed.
Thanks to chatgpt for helping me find this (and writing that summary above).
Quick checks:
If you see:
127.0.0.1#5053
Also check:
Then test:
I'll take a look at this later. Thanks
I noticed something odd a couple of months ago, I thought DNS was running slowly but couldn't work out why. the graphs on both my Piholes looked perfectly normal, but I spotted this morning that my PRTG instance was showing a DNS failure on the primary. Did some actual proper tests and then discovered that couldflared had changed, which is what was causing the slowdowns. Devices were querying the primary, but then timed out before switching to secondary.
Now it's back to normal, super speedy.
Why proxy DoH with cloudflared in the first place? I’m assuming it’s because pi hole doesn’t support it out the box?
Is there a solution for pi hole and DoH without cloudflared? Or to fix can you point cloudflared to a different company DoH server upstream?
My router supports one or many DoH upstream servers as well as blocklists so I’ve moved away from pi hole now.
Yes, you can just use dnscrypt-proxy for DoH with pi-hole.
