SFX & SFX-L Advice
21 May 2018
South Wales
I've just received a Lian-Li O11 Dynamic Mini and now in search for a quality SFX PSU.
Any advice on which unit to get as it needs to be paired with a 5600x and 3070 Ti.
The Corsair SF units are argueably the best available and would be my personal choice. The 600w is gold rated while the 750w is platinum rated. You shouldn't need the power of the 750w for your pc but that would be my choice for future proofing and the extra efficiency.
The Seasonic SGX units are worth a look but they are a bit larger if space is a premium.
I would avoid the BeQuiet PSU's with their short warranties.
Do both come with the braided cables as I noticed the 750 version does?
The 600w has flat ribbon style cables. The 750w is probably intended to be a premium product hence the Platinum rating and nice cables.
Thanks for your help! Will order the SF 750w as I intend to upgrade the CPU etc in the future.
This is incorrect.
There are two lines of Corsair SF PSU. SF Gold and SF Platinum.
Gold comes in 450W and 650W, and has the flat ribbon cables.
Platinum comes in 450W, 600W and 750W, and these all have the individually sleeved cables.
I believe the cables are of the ribbon type on the SGX. It depends on the price really because even online it seems overpriced when compared to the Corsair SF 750w platinum.
Price for the SGX is £124.99 and the SF 750 is £132.99.
Tenner cheaper than on here then. For only £8 extra I would probably get the SF750 for the extra 100w and platinum efficiency. The 650w psu's are in a sort of no mans land really. Too much power for the lower rated gpu's and not enough power for the higher rated gpu's. I only got my 650w psu as it was a steal for the price being asked at the time otherwise I would have stuck with the 750w Superflower I had back then.
Went ahead yesterday and got the SF 750 and it's just arrived... by Christ it's tiny! Also came with the NVIDIA 12-pin cable too. That's me case and PSU sorted, just an AIO left now so choices choices.
Torn between the Kraken Z63 or H115i Capellix?
However not keen on the Corsair mounting choice for AMD so learning towards the Z63.
That's new. Was the Nvidia 12 pin in with the rest of the cables? If so they must be including them as standard which is good news.
Indeed it was. After some googling it does appear to be bundled with the SF 750 from now, must be a new revision maybe?
Must be because previously owners had to contact Corsair for the cable so it's nice to see them including it now. Wonder if the other manufacturers will follow suit?
Corsair SFX are indeed good, have the 450W platinum model. The 24pin in very short though, so make sure your case has a small distance, I had to buy an extension, as my Micro ATX board was too large.
Silverstone sometimes make good SFX PSU's too, but are more difficult to find.
Nice! I got my SF750 unit in around December time to go with my RTX3090 and no 12 pin cable so nice to see they are adding them in now, must have been this year sometime so must be new.
Almost finished my build in the O11 Mini and the cable length was spot on, also cable management was a pleasure.
I have an AIB but should I even get a FE this will come in handy.
Just awaiting for 3 QL fans now and hopefully this week may have some pics to show all.
Had the node 801, unfortunately there isn't enough space to route over the top, and the 24 pin is about 1-2 cm too short. Will work in many SFF builds, but mine is sort of in the middle between SFF and below average size.
All done and dusted for now.
Planning towards the end of the year to add an additional 6 fans or replace with 9 of the UL120/140.
