Gilly said:I'm trying to be manly because I think moisturiser is girly?
Gilly said:Dermatitis means you have to be a gay?
Ok :/
perplex said:What is up with all these recommendations? Every face is different and everyone's hair growth is different. It might not be symmetrical either, so study your face and go with the grain first. Then across if you want closer, followed by against for maximum closeness. Try a safety razor too if you're not happy with the cost and/or performance of cartridge razors.
lol it's funny reading all the posts with people trying to be all manly; "OMFG moisturiser? be a man and use your urine" etc. Shaving can be a art if you want it to be, there's forums dedicated to it.
Far too many metrosexuals in here, you probabaly all goto toni and gay for your haircuts too
. When I do shave it's always with the grain, using foam, a mach3 and hot water.
) to close your pores up.shadow4509 said:Ha ha the funny thing is it makes you sound more gay saying that!
Nope. It just sounds queer, what is difficult to understand about that?shadow4509 said:Is there a rule book for men somewhere saying that men must not moisturise?
I know perfectly well what women do and do not find attractive. I don't need to moisturise, none of my friends moisturise and only the metro at work do I know of in RL that moisturises. Hence I find it a bit gay. Don't take it personally.shadow4509 said:just to let you know most women find it more attractive when men take care of their themselves.
Gilly said:I know perfectly well what women do and do not find attractive. I don't need to moisturise, none of my friends moisturise and only the metro at work do I know of in RL that moisturises. Hence I find it a bit gay. Don't take it personally.
I do same as gillyGilly said:Both. Down then up.
Define 'mates'. Do they often disappear together on nights out?geeza said:Is it ok do both then?
I mean the in the case of some of my mates. They will grow a beard/goatee or whatever but will use a hair dryer, straighteners, face packs and will shave their chest and trim around man-meat region
Gilly said:Define 'mates'. Do they often disappear together on nights out?
Same, get the worse of it by going down, then go up. The hair on my neck grows in all directions which is a pain in the ****.Gilly said:Both. Down then up.
