- 9 Jun 2020
Hi All
Just after a bit of advice if possible.
I've got a shed arriving next week and have levelled my ground as best as I can and am using an ecodeck base.
When I lay the ecodeck and check levels it is mostly even but in a few areas it is showing up as uneven, but no more than a cm or so.
Does this matter? Does the ground need to be 100% even in every area or is it passable to be slightly off in places once the shed goes down on the base?
Any advice would be appreciated!
Cheers
Cheers
